Refesher Part Duex - Rectangular -> Cylindrical -> Spherical
In summary, the conversation discusses helping a friend study for their calculus exams, while also refreshing the speaker's own knowledge. They encounter a problem involving a triple integral and are tasked with converting it into cylindrical and spherical coordinates, while also explaining and sketching the region. The speaker runs into a visualization error when setting up the region, but ultimately finds that the boundaries and integrals are correct. However, there is a discrepancy in the solution when using spherical coordinates, and the speaker is unsure where the error lies. They ask for assistance in identifying the mistake.
beer
I'm at it again today. Helping the same friend (plus another) study for their final calculus exams; it's a good refresher for me as well. (I'm a senior industrial engineering major so I'm "done" with calculus, and it isn't used much in our upper level classes nor professionally to the best of my knowledge.)
Yesterday I ran into a "visualization" error on my part. Today, we're (currently) working through the following problem:
∫∫∫ (x2 + y2)1/2 dz dy dx
0 ≤ z ≤ (x^2 + y^2)1/2
0 ≤ y ≤ (25 - x^2)1/2
0 ≤ x ≤ 5
The question doesn't require evaluation of the integral. Rather, it asks to convert the integral into cylindrical coordinates, and into spherical coordinates, and to explain and sketch the region. However, solving the integral yields (625π / 8)
Setting up the region, R, yields an eighth of a sphere with radius 5. I cautiously explained that if they set up their boundaries right in any form of integration (spherical, cylindrical, etc) and integrated over a constant (generally 1), it would yield the volume of R... in this case, (1/8) * (4/3 π 53) = 125π/6. I've never explicitly read or been explained that this is a good check of proper boundaries, but it seems to always hold true.
Converting to cylindrical we had:
0 ≤ z ≤ r
0 ≤ r ≤ 5
0 ≤ θ ≤ π/2
Which yielded the volume of R when integrated over a constant. Assuming these were the correct boundaries. And more importantly:
∫∫∫ r z dz dr dθ = (625π / 8)
Check. Things seem to be in order.Similarly, for spherical, we get that...
0 ≤ θ ≤ π/2
0 ≤ ρ ≤ 5
0 ≤ φ ≤ π/2
These boundaries integrated with a constant yields the the same 125π/6 value of R I assume indicate that the boundaries are indeed correct.
However, when setting up the integral (given the above bounds) I told them it would be:
∫∫∫ρ2 sin(φ) [ρsin(φ)] dρ dθ dφ
There are a few ways to get the [ρsin(φ)] part; direct conversion using the commonly available "rectangular to spherical" formulas, or by noting that r = ρsin(φ) when converting from cylindrical to spherical, etc.
Since the boundaries don't include any variables, the order of integration shouldn't matter. (This is the first red flag in my mind; I recall from habit that most all triple integrals we solved in my Calc III class included variables on the inner bounds)
Solving this integral yields 625π2 / 32.Again, the problem doesn't actually require solving the integrals, but since the solution is different, I assume we set the spherical version up correctly and I can not identify where things went wrong... either in the boundaries (likely) or in the function itself... (also likely.)Any help would be appreciated. Sorry for being so long winded.
0 ≤ x ≤ 5
No, your visualization of R is off on two counts. First, R is not part of a sphere. The "cap" is the upper half of a cone. Second, you're not dealing with an eighth of something - the equation for y in terms of x is a half circle, not a quarter circle
0 ≤ z ≤ r
0 ≤ r ≤ 5
0 ≤ θ ≤ π/2
0 ≤ θ ≤ π/2
0 ≤ ρ ≤ 5
0 ≤ φ ≤ π/2
Related to Refesher Part Duex - Rectangular -> Cylindrical -> Spherical
1. What is the purpose of converting from rectangular to cylindrical to spherical coordinates?
The purpose of converting from rectangular to cylindrical to spherical coordinates is to simplify complex mathematical equations and make them easier to solve. It also allows for a better understanding of the geometry and relationships between different variables.
2. What are the differences between rectangular, cylindrical, and spherical coordinates?
Rectangular coordinates use three values (x, y, z) to represent a point in three-dimensional space. Cylindrical coordinates use two values (r, θ) to represent a point in the xy-plane, and a third value (z) for the height. Spherical coordinates use three values (r, θ, φ) to represent a point in three-dimensional space, with r being the distance from the origin, θ being the angle from the positive x-axis, and φ being the angle from the positive z-axis.
3. How do you convert from rectangular to cylindrical coordinates?
To convert from rectangular to cylindrical coordinates, you can use the following equations:
r = √(x^2 + y^2)
θ = arctan(y/x)
z = z
4. How do you convert from rectangular to spherical coordinates?
To convert from rectangular to spherical coordinates, you can use the following equations:
r = √(x^2 + y^2 + z^2)
θ = arctan(y/x)
φ = arccos(z/√(x^2 + y^2 + z^2))
5. What are some real-world applications of converting between rectangular, cylindrical, and spherical coordinates?
Converting between these coordinate systems is commonly used in physics, engineering, and mathematics to solve problems involving three-dimensional space. For example, it can be used to calculate the position and trajectory of objects in motion, map out three-dimensional surfaces, or analyze data from scientific experiments.
11K
  • Linear and Abstract Algebra
