Reflecting glass and a convex mirror.
In summary, the converging lens and plane mirror create an image of the object 1m in front of it. The image distance is -1 with respect to the mirror.
Alpha Russ Omega
30
Hello!
I'm stuck on this problem...
A thin flat plate of partially reflecting glass is a distance (b) from a convex mirror. A point source of light (S) is placed a distance (a) in front of the plate so that its image in the partially reflecting plate coincides with its image in the mirror. If b = 5.20 cm., and the focal length of the mirror is f = - 51.0 cm., find "a" in centimeters.
http://img254.imageshack.us/img254/8801/221ch3031p04lt9.png
I tried solving for p but my answer came out incorrect.
1/p + 1/q = 1/f
p = 1/[(1/f)-(1/q)]
p = 1/[(1/-51.0 cm)-(1/5.20cm)] = ...
Please help me figure out what I'm doing wrong.
Thanks in advance!
Alpha Russ Omega said:
1/p + 1/q = 1/f
p = 1/[(1/f)-(1/q)]
The object distance from the convex mirror is a+b, not b. (What must the image distance be?)
Ah... So the image distance must be b-a. Thus: [1/(a+b)]+[1/(b-a)]=1/f
Then I would probably just solve for a.
Thanks for your help!
Converging lens, object, and mirror
Sorry for double posting, but I'm stuck on a similar one. This one is even more confusing to me. :frown:
"An object is placed 1.00 m. in front of a converging lens, of focal length 0.54 m., which is 2.00 m. in front of a plane mirror. How far from the lens is the final image located (in meters), if viewed by looking toward the mirror through the lens?"
I couldn't find a graphic for this problem so I drew something that could look like what they are describing.
http://img123.imageshack.us/img123/5583/physicsmadnessqp5.png
I'm not even sure how to apply the previous equation here. Hopefully I drew the picture correctly.
Can that a+b or b-a method apply here as well?
Thanks in advance for any help!
Do it step by step. The light is first focused by the lens: find the image location. That image becomes the object for the plane mirror: find its image. Now that image becomes the object for the second pass through the lens (in the opposite direction): find that image, which is the final one.
Give it a shot.
Alrighty, I got it figured out. Thanks! I did the step-by-step thing and that worked out nicely.
I'm stuck on the second question as well. Applying the method suggested by Doc Al, I calculated the image distance for the image initially formed by the lens using the thin lens equation as follows:
1/1 + 1/i = 1/0.5 (in my version of the question, f = 0.5m, not 0.54m)
Therefore, i = 1. Thus, the image is formed 1m between the converging lens and the mirror.
Applying the equation i = -p for the mirror, you get an image distance of -1 with respect to the mirror.
Then, applying the thin lens equation again for this image, with the light now traveling in the opposite direction (compared to when the equation was first used), I got:
-1/3 + 1/i = 1/0.5
Therefore, i = 3/7. Thus, the image is 3/7m from the lens, on the side of it closest to the mirror.
My textbook gives the answer as 0.6m, however, with the image being on the other side of the lens.
I think I must have misunderstood the sign conventions for the thin lens equation. I have p = -3 and f = 0.5 the second time I'm applying the equation because this time, p is 3m on the other side of the lens, while f remains unchanged. It seems that to get an answer of 0.6m, however, p and i have to have the same sign.
Any help with this would be much appreciated.
Since the light (on its second pass) is moving from right to left, that's the orientation you should use. The object distance for that pass should be positive. (You only use a negative object distance for virtual objects.)
Related to Reflecting glass and a convex mirror.
1. What is reflecting glass?
Reflecting glass, also known as a mirror, is a type of smooth and shiny surface that reflects light, creating an image of whatever is placed in front of it.
2. How does reflecting glass work?
Reflecting glass works by reflecting light rays that hit its surface. These light rays bounce off the surface at an angle equal to the angle at which they hit the surface, creating a virtual image of the object in front of the glass.
3. What is a convex mirror?
A convex mirror is a type of curved mirror where the reflective surface bulges outward. This causes light rays to diverge, creating a virtual image that is smaller and upright compared to the actual object.
4. How does a convex mirror differ from a regular mirror?
A convex mirror differs from a regular mirror in terms of its reflective surface. While a regular mirror has a flat reflective surface, a convex mirror has a curved reflective surface that bulges outward. This causes light rays to diverge, creating a smaller and upright virtual image.
5. What are some common uses of a convex mirror?
Convex mirrors are commonly used as security mirrors in stores and public places, allowing for a wider field of view. They are also used in vehicles as side-view mirrors to provide a wider view for the driver. Additionally, they are used in some telescopes and other optical devices to help magnify images.
