Reflection and Transmission of acoustic waves at a boundary
The discussion focuses on calculating the acoustic impedances of aluminium and copper, which are essential for understanding wave behavior at their boundary. The characteristic impedances were determined to be 1.73 x 10^7 and 4.33 x 10^7, respectively. Participants clarified that the reflected and transmitted wave amplitudes should be expressed as ratios relative to the incident wave amplitude, which can be set to 1 for simplicity. This approach allows for the calculation of the reflection and transmission coefficients, which indicate the percentage of incident power that is reflected and transmitted. Overall, the conversation emphasizes the importance of understanding ratios in wave transmission and reflection at material boundaries.
Nerrad
An interface is formed between a block of aluminium (density = ##2.70 \times 10^3 kg/m^3##, speed of sound =##6.40 \times 10^3m/s##) and a block of copper (density = ##8.96 \times 10^3 kg/m^3##, speed of sound =##4.76 \times 10^3m/s##). Longitudinal waves traveling through the aluminium are normally incident on the boundary, and are partially reflected. Calculate:
(a) The acoustic (characteristic) impedances of aluminium and copper;
(b) The amplitudes of the reflected and transmitted waves, relative to the incident wave;
(c) The percentage of the incident power that is transmitted and reflected.
(a) The acoustic characteristic impedance of a material is given by:
$$Z = \rho v \text{ (1)}$$
where ##\rho## is equal to the density of the material and ##v## is the acoustic velocity
(b) Reflection coefficient is given by :
$$\frac {A_r} {A_i} = \frac {Z_1-Z_2} {Z_1+Z_2} \text{ (2)}$$
Transmission coefficient is given by:
$$\frac {A_t} {A_i} = \frac {2Z_1} {Z_1+Z_2} \text{ (3)}$$
(a) By using equation 1, I've obtained impedances of ##1.73 \times 10^7## and ##4.33 \times 10^7## respectively.
(b) I have to work out the amplitudes relative to the incident wave, but I'm not given the amplitude of incident wave, so how do I go about tackling this question? Thanks
Read this carefully. You are asked to find the reflected and transmitted amplitudes relative to the incident wave amplitude. What does that mean?
Does it have something to do with ratio? To me it's quite vague
Yes, it has to do with ratio. Call the incident amplitude 1 and find the reflected and transmitted amplitudes as a fraction of 1.
Oh so what you mean is that it doesn't matter what I set the incident amplitude as, because at the end I'm going to get a percentage/ratio of it? Kinda like how for probability it all adds up to 1?
Exactly.
Likes Nerrad
  • · Replies 17 ·
