Reflection maximum of material
In summary, the problem involves adding a coating with a refractive index of 1.33 to a glass with a refractive index of 1.50 in order to create an "iridescent" effect. The question asks for the thinnest layer of material that will produce a maximum reflection for normal-incidence light at both 400 and 600 nm wavelengths. It also asks for the wavelength of the reflection minimum for this thickness. A diagram is provided and it is noted that there is a 180 degree phase change due to the difference in refractive indices. Interference between light reflected at the first and second surfaces must be taken into account to achieve the desired properties.
salmayoussef
31
A coating of n1 = 1.33 material is to be added to n2 = 1.50 glass, in order to make it "irridescent."
a) What is the thinnest layer of material which will have a reflection maximum for normal-incidence light at BOTH 400 and 600 nm (vacuum) wavelength?
b) This thickness will have a reflection minimum at some wavelength between 400 and 600 nm. What is the wavelength of the reflection minimum?
Known:
n1 = 1.33 (coating)
n2 = 1.50 (glass)
3. The Attempt at a Solution
I drew a diagram, but I don't know how to begin to go about this problem. Can someone please guide me?
I also know there's a 180 phase change because n2 > n1.
You get interference between light that gets reflected at the first surface and light that gets reflected at the second surface. They need a special relationship to give the properties you want.
Related to Reflection maximum of material
1. What is the reflection maximum of a material?
The reflection maximum of a material refers to the maximum amount of light or other electromagnetic radiation that can be reflected by the material. It is a measure of the material's ability to reflect incident waves.
2. How is the reflection maximum of a material determined?
The reflection maximum of a material is determined by its physical properties, such as its composition, surface roughness, and thickness. These properties affect how much of the incident wave is absorbed or transmitted, ultimately determining the amount of reflection.
3. Is the reflection maximum of a material the same for all wavelengths?
No, the reflection maximum of a material can vary depending on the wavelength of the incident wave. This is because different wavelengths interact with materials in different ways, and some may be absorbed or transmitted more than others.
4. How does the reflection maximum of a material affect its appearance?
The reflection maximum of a material can greatly impact its appearance. Materials with a high reflection maximum will appear brighter and more reflective, while those with a low reflection maximum will appear darker and less reflective.
5. Can the reflection maximum of a material be altered?
Yes, the reflection maximum of a material can be altered by changing its physical properties or by applying a coating or treatment. For example, adding a mirror-like coating to a material can greatly increase its reflection maximum.
