Reflective solar shortwave & emissive long range film?
In summary, the conversation is about recommendations for commercially available films and coatings that have maximum reflectance for short wave sunlight, some long wave reflectance, good emissivity for all spectra, and high thermal conductivity. The second person also asks for suggestions for a coating that has maximum emissivity for long wave spectrum and is thermally conductive. The suggested solution is Solar Film, a plastic film that can be applied to windows to reduce heat gain from direct sunlight, but it may also reduce visible light. The person is also interested in aluminum radiant barrier and flat black paint for solar heat reflection and absorption, but is looking for any new and improved products.
shane2
89
Looking for recommendations for two commercially available films and coatings, the best for...
#1 - Maximum reflectance, regardless AOI, for short wave sunlight primarily and, secondarily,
reflects some or a lot of long wave, and thirdly, also good emissivity for any of the spectrum.
Appreciate any suggestions for commercially available film and also for a coating.
#2 - A coating or paint that has maximum emissivity for majority and/or peak of long wave
spectrum and is, secondarily, also highly thermally conductive, too.
Thank you for any suggestions.
Solar Film as sold in larger hardware stores in the U.S. It is a plastic film you apply to windows to reduce heat gain from direct sunlight. We had to put it on our South facing bedroom window so the window air conditioner could keep the room cool in the Southern California Summer. It does cut quite a bit of visible light though, which isn't necessarily a bad thing in a bedroom.
I've been a fan of aluminum radiant barrier for years for reflecting solar heat and flat black paint for gaining it or emitting it, but am checking here for what's 'new & improved' to squeeze the maximum %'s.
Related to Reflective solar shortwave & emissive long range film?
1. What is reflective solar shortwave & emissive long range film?
Reflective solar shortwave & emissive long range film is a type of film that is designed to reflect and emit specific wavelengths of light. It is commonly used in solar energy systems to help increase efficiency and reduce heat transfer.
2. How does reflective solar shortwave & emissive long range film work?
This type of film works by reflecting shortwave solar radiation, which is the heat and light from the sun, while also emitting longwave radiation from the surface of the film. This helps to reduce the amount of heat that is absorbed by the surface, keeping it cooler and more energy efficient.
3. What are the benefits of using reflective solar shortwave & emissive long range film?
There are several benefits to using this type of film, including increased energy efficiency, reduced heat transfer, and improved comfort in buildings. It can also help to reduce the amount of energy needed for air conditioning and other cooling systems.
4. Is reflective solar shortwave & emissive long range film environmentally friendly?
Yes, this type of film is environmentally friendly as it helps to reduce energy consumption and can be used in place of traditional cooling systems, which can have a negative impact on the environment. It is also recyclable and can be reused in other applications.
5. How is reflective solar shortwave & emissive long range film installed?
Reflective solar shortwave & emissive long range film can be installed on various surfaces, such as windows, roofs, and walls. It is typically applied using an adhesive or by using a special film applicator. It is important to follow the manufacturer's instructions for proper installation.
  • Art, Music, History, and Linguistics
