Refraction and bending of light
In summary, the nature of force in refraction is not applicable in modern quantum mechanics. In a naive Newtonian model, a photon can be compared to a snooker ball on a tilted table, with the refraction caused by a change in velocity as it crosses the surface. However, in reality, there is no force involved in refraction, it is simply a result of the difference in velocity between two materials with different refractive indices. This is consistent with the rules for classical waves, where a change in refractive index will alter the direction of propagation if the wave enters at an angle other than 0 or 90 degrees.
sharma_satdev
33
please let me know what is the nature of force that bends the path of photon during refraction.
Science news on Phys.org
There is no such thing as 'force' in modern, quantum-mechanics, approach.
In naive Newton's mechanistic model of light you may treat photon as a snooker ball, but not at the flat table, but rather on the one with one half lifted a bit comparing to other, so the photon receives impulse perpendicular to the refractive surface as crossing it.
There is no force involved in refraction it is caused purely by difference in the velocity of light in the two materials with different refractive indices.
Please note that the rules for classical waves also don't have a force altering the direction a wave propagates in. When the index of refraction changes bewteen two mediums the waves will have their path altered if they are entering the new medium at anything other than a 0 or 90 degree angle.
The nature of the force that bends the path of a photon during refraction is electromagnetic force. This force is caused by the interaction between the electric and magnetic fields of the photon and the surrounding materials. When a photon enters a new medium, such as air to water or air to glass, the electrons in the material are disturbed by the electric field of the photon. This disturbance causes the electrons to oscillate, creating a secondary electric field that opposes the direction of the incoming photon. This interaction causes the photon to change its direction, resulting in the bending of the light. This phenomenon is described by Snell's law, which relates the angle of incidence and the angle of refraction to the refractive index of the material. In summary, the bending of light during refraction is due to the electromagnetic force between the photon and the surrounding material.
Related to Refraction and bending of light
1. What is refraction?
Refraction is the bending of light as it passes through different mediums with different densities, such as air and water. This causes the light to change direction and speed, resulting in objects appearing distorted or shifted when viewed through the medium.
2. What causes refraction?
Refraction is caused by the change in speed of light as it passes through different mediums. This is due to the change in density of the medium, which causes the light to bend in order to maintain its constant speed.
3. How does the angle of incidence affect refraction?
The angle of incidence, which is the angle at which a light ray enters a medium, determines the amount of bending that will occur. The greater the angle of incidence, the greater the amount of refraction will be.
4. What is the difference between refraction and reflection?
Refraction is the bending of light as it passes through a medium, while reflection is the bouncing of light off of a surface. Refraction changes the direction and speed of light, while reflection does not.
5. What are some real-life applications of refraction?
Refraction has many practical applications, such as in eyeglasses and contact lenses, where the bending of light helps to correct vision. It is also used in the design of lenses for cameras and telescopes, as well as in the creation of optical illusions.
