Refraction and Reflection of light
In summary, the material used as an antireflective coating on glass with an index of refraction n = 1.50 has a phase shift of 180° at the interface between air and the coating, 151.37° at the interface between the coating and the glass, and a minimum thickness of 212.5 nm to minimize reflection of light with wavelength λ = 555 nm.
dangish
75
7. (a) A material having an index of refraction n = 1.30 is
refraction n = 1.50 as shown.
(i) What is the phase shift for the reflection at the interface
between air and the coating (interface 1)?
(ii) What is the phase shift for the reflection at the interface
between the coating and the glass (interface 2)?
(iii) What minimum thickness must the coating have in order
to minimize reflection of light with wavelength λ = 555 nm?
I thought when something gets reflected it is always 180deg.
any ideas on this one?
(i) The phase shift for the reflection at the interface between air and the coating (interface 1) is 180°.(ii) The phase shift for the reflection at the interface between the coating and the glass (interface 2) is 180° - (2 × arcsin[n1/n2]) = 180° - (2 × arcsin[1.30/1.50]) = 151.37°.(iii) The minimum thickness of the coating must be λ/(4n) = 555 nm / (4 × 1.30) = 212.5 nm in order to minimize reflection of light with wavelength λ = 555 nm.
Related to Refraction and Reflection of light
1. What is refraction of light?
Refraction of light is when light passes through a medium, such as air, water, or glass, and changes direction due to the change in its speed. This change in direction is caused by the light bending as it enters and exits the medium, resulting in the light appearing to be "bent".
2. How does refraction of light occur?
Refraction of light occurs because light travels at different speeds through different mediums. When light travels from one medium to another, its speed changes, causing it to bend and change direction.
3. What is the difference between refraction and reflection of light?
Refraction and reflection are two different phenomena that occur when light interacts with a surface or material. Refraction is the bending of light as it passes through a medium, while reflection is the bouncing of light off a surface. Refraction causes the light to change direction, while reflection causes the light to maintain its original direction.
4. How do lenses use the principles of refraction to focus light?
Lenses use the principles of refraction to focus light by manipulating the direction of the light rays. Convex lenses, such as those used in magnifying glasses, bend light rays towards a central point, while concave lenses, like those in glasses, spread out the light rays. This bending of light allows lenses to form images and focus light onto a specific point.
5. What are some real-life applications of refraction and reflection of light?
Refraction and reflection of light have many practical applications in our daily lives. Examples include the use of lenses in eyeglasses, telescopes, and microscopes, the creation of rainbows and mirages, and the use of prisms in photography and spectroscopy. These phenomena are also important in understanding how light behaves in different environments, such as underwater or in the atmosphere.
