Refraction and total internal reflection
In summary, when a mixture of red and violet light is incident on a glass-air interface with indices of refraction n(red)=1.52 and n(violet)=1.538, the critical angle for violet light is 40.56 degrees and 41.14 degrees for red light. The light enters at a 40.85° angle, which is greater than the critical angle for both red and violet light, resulting in total internal reflection.
calgal260
A mixture of red and violet light is incident on a glass-air interface. The indices of refraction for red and violet light in glass are n(red)=1.52 and n(violet)=1.538. What color of light enters the air?
http://www.webassign.net/cj8/q_10.gif
attempt to solve:
I found that the critical angle for the violet light is 40.56 degrees and 41.14 degrees for the red. If the critical angle for the red light is larger, shouldn't there be total internal reflection?
Thanks in advance!
At which angle does total reflection happen? Greater or lower than the critical angle?
ehild
ehild
Greater than the critical angle, right? That is what I'm getting but this problem is confusing. I must be doing something wrong.
The light enters at the glass-air interface at 40.85° angle. For which light is this angle greater than the critical one?
ehild
I would like to clarify that refraction is the bending of light as it passes through different mediums, while total internal reflection occurs when a light ray is completely reflected within a medium due to the angle of incidence being greater than the critical angle.
In this scenario, the mixture of red and violet light is incident on a glass-air interface, where the indices of refraction for red and violet light in glass are n(red)=1.52 and n(violet)=1.538. This means that the speed of light is slower in glass than in air, causing the light to bend as it enters the glass. The amount of bending depends on the wavelength of the light, with shorter wavelengths (such as violet light) bending more than longer wavelengths (such as red light).
Based on the given indices of refraction, we can calculate the critical angle for each wavelength using the formula sinθc = n2/n1, where n2 is the index of refraction for air (which is approximately 1) and n1 is the index of refraction for glass. For red light, the critical angle is 41.14 degrees, and for violet light, it is 40.56 degrees. This means that for the violet light, the angle of incidence would need to be larger than 40.56 degrees in order for total internal reflection to occur, while for red light, the angle of incidence would need to be larger than 41.14 degrees.
To answer your question, the color of light that enters the air in this scenario would be a mixture of red and violet light, with the violet light being slightly more bent than the red light due to its shorter wavelength. The amount of bending for each color can be calculated using the formula θ = sin^-1(n2/n1), where θ is the angle of refraction. So for violet light, the angle of refraction would be approximately 25.37 degrees, while for red light, it would be approximately 24.78 degrees.
In conclusion, the critical angle for a specific wavelength of light depends on the index of refraction of the medium it is passing through. While the critical angle for violet light is smaller than that of red light in this scenario, it does not necessarily mean that total internal reflection will occur for violet light. The specific angle of incidence and the angle of refraction also play a role in determining whether total internal reflection will occur.
Related to Refraction and total internal reflection
1. What is refraction and how does it occur?
Refraction is the change in direction of a wave as it passes through a medium with a different density. This occurs because the speed of the wave changes as it enters the new medium, causing it to bend.
2. What is the law of refraction?
The law of refraction, also known as Snell's law, states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the speeds of the wave in the two media.
3. How does total internal reflection occur?
Total internal reflection occurs when a wave reaches a boundary between two media and is completely reflected back into the original medium because the angle of incidence is greater than the critical angle for that boundary.
4. What factors affect the amount of refraction?
The amount of refraction is affected by the speed of the wave in the two media, the angle of incidence, and the difference in density between the two media.
5. What are some real-world applications of total internal reflection?
Total internal reflection is used in many everyday devices, such as optical fibers for telecommunication, prisms in binoculars and cameras, and optical sensors for touch screens. It is also used in medical imaging techniques like endoscopy and microscopy.
