Refraction (aperture, apparent depth)
In summary: If air has a higher index than glass, then light will spend more time traveling through the air than the glass, and the apparent image will be behind the glass.
rishch
106
1: A decrease in the aperture of a lens changes the
(A)Size of the image
(B)Intensity of the image
(C)Portion of the image
(D) All of these
2: A vessel is filled with two different liquids which do not mix. One liquid is 40cm deep and has n=1.6 and the other is 30cm deep and has n=1.5. What is the apparent depth of the vessel when viewed along the normal?
1: None
2: n=real depth/apparent depth
1: The first ones answer is supposed to be (B)Intensity of the image. I don't know what intensity of an image is though, and I googled it but nothing came up. My answer would've been (C)Portion of the image, but I don't know what that exactly means either, but I'm assuming it means how much of the image you can see, and since the aperture decreases, that should decrease too.
2: This one is really weird an I have no idea how to solve it. The solution is-
n1 = 1.6, d1 = 40 cm
n2 = 1.5, d2 = 30 cm
Apparent depth d = ?
n = real depth (D)/apparent depth (d)
⇒ d = D/n = d1/n1 + d2/n2
d = (25 + 20) cm = 45 cm
But how do they get d = D/n = d1/n1 + d2/n2? They have a video which goes into a bit more detail but I still don't get it :/ Could someone explain?
Every part of the scene still has straight line access to the centre of the aperture, so the light rays entering the aperture still represent the entire scene. But beyond the aperture is the lens. As the aperture is narrowed, each part of the scene can reach less of the lens and therefore contributes fewer photons to the image. Thus the brightness of the image is reduced.
The refractive index, n, tells you the relative speed of light through the medium, c/n. Light travels by the shortest time route. When light passes through a medium boundary at an angle to it, the shortest time route is different from the shortest space distance; it will be biased toward spending less distance in the slower medium. When you trace the rays back to find their apparent source, you find that the apparent distance from the boundary shrinks in proportion to the refractive index of that medium. So when light travels a distance d through a medium of index n, an observer in air will perceive it has only having traveled d/n.
True, but what matters is the light entering our eyes. While the totally, fewer number of photons would seem to come out from the image, but in reality each point on the image is still emitting the same number of photons in each direction, it's just that now they're emitting in less directions, so for an observer the brightness should remain the same. But since the aperture decreased, you could say that the field of vision is narrowed and we can see less of the image so the portion of the image that we could see would reduce, right?
haruspex said:
The refractive index, n, tells you the relative speed of light through the medium, c/n. Light travels by the shortest time route. When light passes through a medium boundary at an angle to it, the shortest time route is different from the shortest space distance; it will be biased toward spending less distance in the slower medium. When you trace the rays back to find their apparent source, you find that the apparent distance from the boundary shrinks in proportion to the refractive index of that medium. So when light travels a distance d through a medium of index n, an observer in air will perceive it has only having traveled d/n..
Yes, I know how to calculate the postion of the apparent image if you have two mediums, say a bird in air looking at a fish in water. The two mediums are air and water. But in this question there are three mediums. You have air on the top, you have the medium with refractive index 1.5 on top in the beaker and at the bottom of the beaker, for a depth of 40cms, you have the medium with refractive index 1.6.
So if you were to look at the two mediums separately, in two separate beakers, with your head in air, then you could say the apparent depth of the bottom of the beaker = real depth/refractive index. But when you put the two mediums together, you can't simply add the apparent depths because, for the second medium at the bottom of the beaker, light is traveling from a medium of refractive index 1.6 to one of 1.5! It's not traveling into air.
So here's what I did.
I took the bottom medium and and the upper medium and calculated the relative refractive index of the bottom medium with respect to the first. Now the actual formula if you're observing an object in a denser medium from a rarer medium that need not be air is,
apparent depth= real depth/relative refractive index of denser medium with respect to first.
So I got apparent depth if your head is in the upper medium will be 40/(1.6/1.5)
Here 40 is the real depth of the bottom of the beaker and 1.6/1.5 is the relative refractive index. So this is the apparent depth. As you move your head out into the air this virtual image can be considered as an object in the upper medium. It's depth will be,
30+(40/(1.6/1.5))
You can apply the normal formula here as you are observing from air. Then,
apparent depth= [30+(40/(1.6/1.5))]/1.5
=45
45 is the answer they got. If instead of substituting values you leave them as variables, you get the formula they used, that is,
Apparent depth for the whole thing=d1/n1+d2/n2
However, they used that without giving any explanation, so I was left confused. I still can't intuitively grasp the formula as it doesn't seem very...natural? Can anyone here get the formuala intuitively?
Can anyone explain the first question?
Absolutely the opposite !
Suppose the image falls on a screen. Then fewer photons hitting any part of the screen means that fewer photons are reflected in each and every direction.
Draw a ray diagram. The size of the aperture at the lens (the amount of area of the lens which is allowed to pass light) does not affect the field of view.
The top drawing shows how the lens refracts the light incoming rays to form an image of the point behind it. In the bottom drawing the lens is stopped down (apparture decreased), so the image is formed with less light and thus it has a lower intensity.
Ah yes now it all makes sense. I was imagining a virtual image, in which case I think what I said is correct. If you were to take a convex lens to form a virtual image, like a magnifying glass, the smaller magnifying glass would still make an image of the same brightness, but you wouldn't be able to see as much of the image. In case of a real image where you capture the image on a screen, what you said makes complete sense. I figured it out today morning when I was reading how the iris contracts to control the brightness of the image formed on the retina and I thought "Ohhhhh! So that's what he meant!" Sorry, I was thinking about virtual images. However, in case of virtual images, is what I said correct? That to us, the image would appear just as bright.
So what I meant is while in a virtual image the image remains the same, the amount of it that we can see reduces. Am I correct? Oh and can anyone give some feedback on the second question and my solution?
Related to Refraction (aperture, apparent depth)
1. What is refraction and how does it occur?
Refraction is the bending of light as it passes through a medium with a different optical density, such as from air to water. This bending is caused by a change in the speed of light, which occurs due to the change in the medium's density.
2. How does the aperture affect refraction?
The aperture, or the size of the opening through which light enters, can affect the amount of refraction that occurs. A larger aperture allows more light to enter, which can result in a greater amount of bending. On the other hand, a smaller aperture can result in less refraction.
3. What is the relationship between refraction and apparent depth?
Refraction can cause objects to appear to be at a different depth than they actually are. This is because the bending of light can make the object appear to be in a different position than its actual location.
4. How can refraction be used in everyday life?
Refraction is used in many everyday applications, such as glasses and contact lenses, which use lenses to refract light and correct vision. It is also used in cameras and microscopes to focus light and create clear images.
5. What factors can affect the amount of refraction that occurs?
The amount of refraction that occurs can be affected by the angle at which light enters the medium, the difference in optical density between the two mediums, and the wavelength of the light. Other factors such as temperature and pressure can also affect the amount of refraction.
13K
