Refraction in a medium with a gradient of refractive index
In summary, the ray tracing method works well for finding the path taken through the 'graded index, step by step.. The problem is, however, when the ray is almost horizontal and the difference in index at the two levels approaches zero.
Gobil
59
Hi Folks,
After a general search online, I have not yet found a simple description of refraction in a medium with an inhomogeneous refractive index.
For example: if we have a block of glass with a beam of light shining through it, and the block has a gradient in the real part of the refractive index perpendicular to the direction of beam propagation, what will be the angle it exits the block with?
I assume the fromula will depend on the gradient and the thickness of the block, but I don't know how.
Also an intuitive picture would help me here, the light has different velocities, but favors the faster route right, so why then does it tend towards the values with higher n? Where it is slower! See wiki GRIN lenses.
Many thanks!
Science news on Phys.org
You can model this as a large number of small changes in the refraction index and let this number go to infinity. If you are just interested in the angle and the modification of refractive index is linear in one coordinate: Use that sin(theta)*n is constant, where theta is the angle relative to this coordinate.
The light takes the fastest route to a given endpoint. Look at where the light started and finished, and you'll see that in between it curved so as to go through less dense medium before having to head off to its destination.
In addition, it takes the fastest way only locally, not globally. Light will still go through some meters of glass, even if there would be a bended way around the glass (at least without diffraction).
thanks for the responses guys.
so, ignoring density for a while, and just thinking about the refractive index gradient, let's assume it´s a linear change in space perpendicular to the beam propagation direction. The light bends towards the slower part, i.e. it will tens to bend to the places with higher refractive index. Is this because the tranverse fields are slowed down there, kinda causing it to bend?
Also the equation sin(theta)*n= constant doesn´t really help much, how is the gradient and thickness of the glass taken into account?
thanks!
Gobil said:
lets assume it´s a linear change in space perpendicular to the beam propagation direction.
In that case, refraction does not change the angle at all.
Refraction occurs because the phase velocity is different for different media, right.
That is the nice property of this equation: The details don't matter. You have some refractive index n1 outside (usually ~1), an angle between the light and the change of refractive index theta1 and some value n2 at point x in the glass, and you can calculate the angle of the light theta2 there.
From what I've read this is not true: wiki GRIN lenses. They focus light by having a refractive index gradient inside the material. The actual optic is cOmpletely flat, and the light enters perpendicular to the gradient. I just can't find an equation to describe this. Or a picture of what's going on microscoPically.
Thanks for the comments!
The light which actually enters perpendicular to the gradient is not bent, just the light which has a small angle. See the wikipedia article, there is a good image of that.
I remember doing some work on modelling the ionosphere in connection with MF (mainly) Radio Wave propagation. The refractive index, in that case, depended on the level of ionisation at different heights. The ray tracing method worked pretty well for finding the path taken through the 'graded index, step by step.. The problem was, however, when the ray was almost horizontal and the difference in index at the two levels approached zero. The ray 'never got down again'. I found a solution by recognising when the height steps got too small and then did a simple reflection calculation at that very shallow angle. Then you could go down again with no trouble. It worked pretty well as a method for predicting MF skywave interference. Of course, just like the weather, lower down, predicting the actual levels of ionisation at different heights was a bit hit and miss - but that was someone else's problem.
I think this is incorrect, and it´s just the way the graphic looks.
for example see the attached image, from: http://www.grintech.de/gradient-index-optics.html
it shows all the perpendicular rays being bent, which is the principal of these optics
Assuming Snell's law works. Normal incident rays leave normally .
If a graph or a simulation appears to give odd results, suspect it rather than the basic theory. Imo, simulations can lead you into trouble if you are not careful.
Ok, http://www.grintech.de/tl_files/content/gradientenoptik/Strahlverlauf_in_einer_GRIN-Sammellinse_mit_verschiedenen_Pitchlaengen.gif.jpg is very convincing in that respect. You are right, assuming the creators of the images knew what they did (I think this is true).
It is not a contradiction to my formula - sin(theta) is 1 at the points where the light "turns", this allows to calculate the angle at higher refractive indices. For lower refractive indices, sin(theta) would have to be larger than 1, which is impossible. But it might be a bad approximation very close to these turnaround points.
The actual tipping point for the ray - as it changes lateral direction - must be treated differently from all other parts of the ray. If you just apply Snells Law and a simple 'layered' model, the logic is, I think, that the ray will asymptote to stay parallel to the axis with nothing to turn it inwards again.
μ12 gets closer to 1 as the layers get thinner and angle C becomes closer and closer to 90 and can't ever start to get less?? So it is necessary to put a lower limit on the thickness of elemental slice and 'assume' straightforward reflection in the final slice (by making the assumption that C has been reached), I think.
Something along the line of this, yes.
Here is an approximation for light perpendicular to the diffraction index gradient:
Let's assume a diffraction index of n at position x=0 and a gradient of g along the x-axis. A light ray at x-position 0 therefore has the velocity c/(n) and a light ray at +dx has velocity c/(n+g*dx). Using the approximation g*dx << n, this velocity can be approximated as c/n (1-g*dx/n). This is equivalent to a circle with radius g/n.
It becomes a bit more tricky for light in arbitrary directions, but it should be possible to derive the path of the light there as well, using the same idea.
That's smart. That method gives the angle of the wave front and, hence, the direction of the ray.
Consider a medium occupying the x>0, y>0 quarter plane. R.I at x,y is r = 1+k.x.
Ray enters in the y direction at x =a.
Dy/dx = tan θ.
Sin (θ+δθ)/sin (θ) = (1+k.x)/(1+k.x+k.δx)
From these I get
1+k.x = c.cosec(θ), some constant c.
y= (c/2k) ln ((1+cos θ) / (1 - cos θ))
Or something like that.
Am I missing something here? If the gradient is perpendicular to the light then each beam coincides with a contour of n and travels in a straight line across the medium.
This is my take on the problem:
The confusion probably lies in the fact that most of us have only dealt with the case of homogeneous slabs. The best way to think of the problem is in terms of Fermat's Principle in which the path length of the light between any two points represents an extremum. So if the light strikes normally to the homogeneous slab, the extremum path for it to follow is the path of least time, going straight through without refracting. The other extremum path (path of longest time) would be to follow the surface of the slab as a surface wave which we reject for physical reasons.
But now we have light striking an inhomogeneous slab. Now the conditions for the extremum path differ. Let us take the parabolic profile that changes along the length of the slab where the maximum lies at the center of the slab and the minimum at the slabs edges. Now the path going straight through, given that the incident ray is normal to the slab, is no longer an extremum path. For example, if the light bends away from the center of the slab it will enter parts of the slab with decreasing n and thus increasing phase velocity. Bending away would represent a minimizing path. Bending towards the center would represent a maximizing path as now the index of refraction increases. So regardless of whether or not the physical path is the maximum or minimum path, it cannot go straight through the slab since we can quickly see that the unrefracted path cannot be a maximum.
So now, how do we choose which path represents the physical extremum path, the minimum or maximum? This depends upon the relative change in the index of refraction. Let us make the converging lens which has a parabolic profile that has a maximum index of refraction at the center, [itex] n(x) = -x^2+n_0[/itex]. Now, taking the first order derivative, we see that the index of refraction changes as [itex]n'(x) = -2x[/itex]. So the ray is going to bend towards the center of the lens. This we can see by the resulting sinusoidal path that is shown the previously posted graphic. Note that once the ray has crossed the center axis, it reverses the direction of refraction to go back towards it.
Likewise, if we choose a parabolic profile such that the center is the minimum index of refraction, then we would have a diverging lens because now the first order derivative of the profile is [itex]n'(x) = 2x[/itex].
Good post thanks!
something is still missing for me though, why, microscopically, does it go towards the slower regions? does the phase velocity suffer a drag there and hence tends towards that region?
Fermat's Principle is what it's about.
hmm, Fermat´s principle is simply a rule to follow.
The question can be re-phrased: what is the microscopic reason for Fermat´s principle?
If you're asking why and how the passage of em waves through a medium affects it speed then that is one step in the argument and can be dealt with in QM terms (microscopic?). Then you can deal apply that to how the wave is affected. To get to the 'bending' effect, you only need to apply the ideas of Huygens construction and the resulting curvature of the wavefront as adjacent wavelets have different wavelengths.
You seem to be implying that there is something 'inadequate' in a wave treatment. In a world of duality, surely the most suitable treatment is the one to go for. There is no 'compromise' in that approach.
I see, it´s not that I have a problem with the wave treatment, it´s just I have an image of the the transverse electric field and how it´s affected by the gradient. i.e. slowed down in one of the transverse directions and bent in that direction. but I´m not sure if this is right.
Think about it in terms of the geometry of the wavefront and the way the phase is different for parts of the wavefront that are in different parts of the material. The part of the wave that is in the more dense material will have a shorter wavelength (it's slower). This means that adjacent parts of the wavefront are no longer at right angles to the gradient of the index - giving a tilted wave. I don't think in terms of the E fields being 'bent' so much as the wavefront becoming distorted.
If you draw parallel lines ( waves forming a 'ray') on a square sheet of rubber (only in your head) and then stretch the sheet on one side of this 'ray', the spaces between the lines will no longer be the same and the normals to these lines ( the direction of the ray) will be bent away from the stretched side of the sheet, bending the direction of the ray. This is strictly a macroscopic/ wave approach but why not? Your E fields will be a right angles to the new wave front.
One of the cleanest ways to look at propagation in a medium with slowly changing index consists in using the WKB approximation. That is one assumes the wave to be of the form exp(ikr-iwt) with abs(k)/w=n(r)/c_0. I don't remember the details, but it should be straight forward to derive an equation for the direction of k by using this ansatz in the Maxwell equations.
This paper by Ambrosini et al has a very detailed analysis of a laser beam passing through a gradient index medium. The paper is useful because it stresses the Hamiltonian analogy between such a light beam and a particle in a gravitational potential field.
Fig. 3 in my http://www.ne.jp/asahi/tamari/vladimir/United-Dipole-Field-Tamari.pdf paper shows how I simulated a streamline bending in a radially dependent continuously changing refractive index medium by repeated applications of Snell's law at each discretely interfaces between wedges having different n values.
Related to Refraction in a medium with a gradient of refractive index
What is refraction in a medium with a gradient of refractive index?
Refraction in a medium with a gradient of refractive index refers to the bending of light as it passes through a substance with a varying refractive index. This occurs when the speed of light changes as it moves from one part of the medium to another.
What causes the gradient of refractive index in a medium?
The gradient of refractive index in a medium occurs when the density or composition of the medium changes gradually. This can be seen in substances such as air, water, or glass, where the temperature or pressure may vary in different regions.
How does the gradient of refractive index affect the path of light?
The gradient of refractive index causes the path of light to bend, as it moves from an area of higher refractive index to an area of lower refractive index. This bending is what causes objects to appear distorted when viewed through a medium with a gradient of refractive index.
Is the angle of refraction constant in a medium with a gradient of refractive index?
No, the angle of refraction is not constant in a medium with a gradient of refractive index. This is because the speed of light changes as it moves through the medium, causing the angle of refraction to vary depending on the location within the medium.
How is the gradient of refractive index measured?
The gradient of refractive index is typically measured using a device called an interferometer, which uses two beams of light to detect changes in the refractive index of a substance. This measurement can also be done using mathematical calculations based on the speed of light in the medium.
  • Atomic and Condensed Matter
