Refraction problem (temperature dependence)
In summary,The problem with doing this experiment using water is that it is not very convenient - the angle of incidence and refraction don't change much over a convenient range of temperatures. The 'pin method' is a more accurate way to do the experiment. Your teacher might be misleading you, as this experiment is not on the school syllabus. However, you can find information about the pin method online. He will need to provide you with some uninterrupted time to do the experiment, as well as a lab space to do it in.
Elbraido
Hi Everybody
I am doing an experiment for a school project where I have chosen to see is the index of refraction changes in a body of water when the temperture changes. So I am using the angle of incidence and refraction to measure using snells law.
The Problem:
Obviously I need a container to hold the water but it will effect my results and how can I resolve this.
Thanks for the help
Science news on Phys.org
If the light enters the water at the top surface (air / water) the container will have no effect. Not as convenient as doing it with a glass block on a bench but, if you can get hold of a container with flat sides, you could put the block against a screen with graph paper on it. Problem is that the RI doesn't change much over a convenient range of temperatures. (Look this up and make sure).
Did you consider using the 'pin' method, rather than just shining a ray? Higher accuracy.
[QUOTE=" 'pin' method, rather than just shining a ray? Higher accuracy.[/QUOTE]
Hi
what is the pin method?
Is this
Elbraido said:
I
Its the same one :).
The post which you mention my teacher told was really difficult and somethings didn't apply for the requirements. so this is the new one.
That one was really difficult and this one isn’t? I think it is the other way around! You are trying to find a variation that is rather small which can easily be beyond what you might be able to detect without expensive, accurate equipment.
Zz.
Likes nasu
Zz.
My teacher told me that it wasn't really an experiment and that I was proving a the theroy and that I needed first hand evidence but he said this one was better.
What do you, and your teacher, think is “first hand evidence” to verify a theory in physics?
Zz.
Hmm. I think your teacher may just be being 'controversial' about this. Look up some facts about the RI of water variations with temperature and ask him if he seriously thinks a simple experiment will show the variation over a convenient and safe range of temperatures that can be measured accurately and has he a method to ensure that the water temperature is uniform.
How many hours of uninterrupted experimental time (and lab space) will he make available to you?
Pin method: I was at school long before laser pointers were available and this was far better than the incredibly naff light boxes that were available but I still think the pin method is preferable for a bench top experiment. Your YouTube video is one example and it actually does the job much better than a laser pointer could. Google Images "Optical pin methods' for many other examples. They are mostly done by sticking (vertical!) pins into a horizontal board with paper on it and using your eye to line them up so that all the pins are hidden by (behind) the one nearest you. The pins are a great, semi permanent record of the experiment and you can draw ray lines and trace the outline of your mirrors / glass blocks etc. and measure angles very accurately after the equipment has been put away.
@Elbraido
This isn't really on the School syllabus, I think, but we did a really clever optics practical in Uni (1966) which was based on the Abbe Refractometer. It is based on the Critical Angle (below which Total Internal Reflection stops) and a small amount of fluid, sitting the back of a glass D is all you need (and you can use the pin method to see the angle where the ray stops escaping from a surface. Look it up. It is potentially quite simple and the temperature of the block / water drop would be easy to measure and maintain.
This refractometer is good for analysing tiny samples of liquids and can tell you the concentrations of solutions etc.
@sophiecentaur
Thanks for your help. Firstly this a do at home experiment with our 3 week holiday coming up and I am also in Australia which I believe is differernt to the syllabus in the UK. Plus your second comment about the Critical Angle, I really like it and i might consider it but could you please send like a diagram of how you would be seting it up. I will add a the assignment notifaction for clarification.
THANKS for the great help so far
  • Task_3_Y10_IRP_2018 (1).docx
That mark scheme looks scary - but they're all like that. The requirement for a log book is a very healthy one and good practice. I must say, I never actually ran one except when required to when I was on courses. Colleagues used them very effectively when they looked back on previous jobs and I was always a bit envious of that resource.
The actual Abbe refractometer is very sophisticated and I'm not suggesting you do the same thing! You can see the effect when you hold a glass of water with water drops on the outside and you can see the pads of your fingers where they actually touch the glass but the edges disappear where light from inside the glass is 'TIR'ed.
If you can get hold of a glass D from college / school, you can firstly use the pin method to see the reflection as with a mirror, with two pins a line on the eye side and you line them up with the images of another two. This link shows the method with a mirror and you can do the same with a D by making sure the pins are positioned radially (normal incidence on the curved face).
That will allow you to find the critical angle for glass by rotating the D until the image disappears. That gives you the RI of the glass. Everything now needs to be done on a vertical plane so that a blob of water will sit at the reflection point. Repeat the same basic operation to find the new critical angle. This will give you the RI of glass into water. The critical angle is much greater because the two speeds are more similar.
The RI of air / water can be calculated by RIaw = RIag/RIgw
I have to go now but will return to this when you get back to me with questions. (You may need to check my formula, btw - it's been a long time . . . .)
Related to Refraction problem (temperature dependence)
1. What is refraction and how does it relate to temperature?
Refraction is the bending of light as it passes through different mediums. The speed of light changes as it moves through materials with different densities, such as air and water. Temperature affects the density of a material, therefore it can also affect the speed and direction of light as it passes through.
2. What is the temperature dependence of refraction?
The temperature dependence of refraction refers to the fact that as the temperature of a material changes, its density also changes. This change in density can cause the speed of light to either increase or decrease, resulting in a change in the angle of refraction.
3. How does temperature affect the refractive index?
The refractive index is a measure of how much light is bent as it passes through a material. The refractive index is directly related to the density of the material, which is affected by temperature. As the temperature changes, the refractive index may also change, resulting in a different angle of refraction.
4. What are some examples of the temperature dependence of refraction?
One example of the temperature dependence of refraction is the phenomenon of mirages in the desert. Hot air near the ground has a lower density than the cooler air above it, causing light to bend and create the illusion of water on the road. Another example is the twinkling of stars in the night sky, which is caused by the varying density of air at different temperatures.
5. How is the temperature dependence of refraction used in practical applications?
The temperature dependence of refraction is utilized in various technologies, such as fiber optics and lenses. By understanding how temperature affects the refractive index, engineers and scientists can design and calibrate these technologies to function accurately in different temperature environments. Additionally, the temperature dependence of refraction is used in meteorology to predict and interpret weather patterns based on the changes in air density caused by temperature fluctuations.
  • Atomic and Condensed Matter
