I Refractive index vs Temperature
The discussion centers on the relationship between refractive index and temperature, particularly in the context of radio wave propagation during temperature inversions. It highlights that during stable, anticyclonic weather, a rise in temperature can lead to a higher refractive index, causing radio signals to bend downwards. The phenomenon is compared to a highway mirage, where light behaves similarly due to changes in temperature and refractive index. The refractive index of air is noted to increase with pressure and decrease with temperature, impacting radio wave behavior. Overall, temperature inversions create conditions that enhance downward ray bending, affecting radio propagation.
jaumzaum
I was studying radio waves phenomenons and found this on Wikipedia:
"Tropospheric ducting is a type of radio propagation that tends to happen during periods of stable, anticyclonic weather. In this propagation method, when the signal encounters a rise in temperature in the atmosphere instead of the normal decrease (known as a temperature inversion), the higher refractive index of the atmosphere there will cause the signal to be bent."
Shouldn't it be lower refractive index? In my mind higher temperatures have less particles and though lower refraction.
I think it is a matter of total internal reflection. The sine of the critical angle is ##\sin\theta_c = \frac{1}{n}##. A signal coming from below at an angle will bend away from the normal at the (cold) - (not as cold) air interface and then away some more at the (not as cold) - (somewhat warm) interface and so on until eventually it reaches the critical angle for total internal reflection and comes back down. It is the same phenomenon as the highway mirage with which you are probably familiar.
Likes vanhees71, DaveE and hutchphd
My understanding is that the refractive index of air increases with pressure and falls with temperature. Overall, the index falls slightly with height, giving slightly downward ray bending. A temperature inversion will give a layer with reduced refractive index, causing energy to be trapped beneath it and giving increased downward ray bending. The radio refractive index is also sensitive to humidity, and so we often have an evaporation duct over the sea.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
