Refrigeration Cycle temperatures
In summary, the temperature at position 1 should theoretically be the same as the temperature at the compressor inlet, but in a real cycle, there may be differences due to superheating and frictional losses. Similarly, the temperature at position 2 should ideally be the same as the compressor outlet temperature, but in reality, there may be differences due to heat transfer and other factors. These differences can be observed in a lab setting, and are caused by frictional losses and heat transfer within the tubing connecting the evaporator to the compressor.
Anony-mouse
60
Please look at the picture on this link of a refrigeration cycle:
http://ffden-2.phys.uaf.edu/212_fall2003.web.dir/Dane_Lenaker/img/pics/frigcycle.gif
Would the temperature at position 1 be the temperature leaving the evaporator or the temperature entering the compressor? or should they in theory be the same? Because according to results i have obtained in a lab, the temp entering the compressor and leaving the evaporator are different. Also, what is the compressor discharge temperature?
Would the temperature of the refrigerant at position 2 be the temperature leaving the compressor? Or would it be also dependent on the compressor discharge temperature?
Thank you
In an ideal cycle the state of the working fluid is the same at the compressor inlet as it is at the evaporator outlet. This means the pressure and temperature will be the same at these locations (with a quality of 1).
However, in a real cycle some things are different. First, a real compressor does not like fluid in it so the cycle is designed in such a way that the inlet gas is superheated a little bit as opposed to sitting exactly on the outer edge of the two-phase region. Also, in a real cycle fluid must be transported from place to place using tubing (copper tubing in a lot of commercial refrigerators). Within the tubing there are frictional losses which can cause a small pressure drop when going from the outlet of the evaporator to the inlet of the compressor. Also, there is often heat transfer between the tubing and whatever environment it is in.
So, long post short. You are likely noticing the differences caused by heat transfer and frictional effects within the tube connecting your evaporator to your compressor.
Also, state 2 is, again, the ideal compressor outlet temperature, but you will likely see similar effects there too.
Related to Refrigeration Cycle temperatures
1. What is the ideal temperature for a refrigerator?
The ideal temperature for a refrigerator is between 35°F and 38°F (1.7°C and 3.3°C). This temperature range is considered safe for storing perishable foods and helps to slow down bacteria growth.
2. What is the purpose of the evaporator in a refrigeration cycle?
The evaporator is responsible for absorbing heat from the inside of the refrigerator and transferring it to the refrigerant. This process lowers the temperature inside the refrigerator and keeps the contents cool.
3. Why is it important to maintain proper temperature in a refrigeration cycle?
Maintaining proper temperature in a refrigeration cycle is important for several reasons. It helps to keep food safe by slowing down bacterial growth. It also ensures that the refrigerator is working efficiently, which can save energy and money.
4. What is the role of the condenser in a refrigeration cycle?
The condenser is responsible for releasing heat from the refrigerant to the outside environment. This process cools down the refrigerant, allowing it to continue absorbing heat from the inside of the refrigerator.
5. How can I troubleshoot temperature issues in my refrigerator?
If you are experiencing temperature issues in your refrigerator, you can try adjusting the temperature setting, cleaning the condenser coils, and checking for any obstructions in the air vents. If these steps do not solve the issue, it may be a sign of a more serious problem and you should contact a professional for assistance.
  • Mechanical Engineering
