Regarding Heat Transfer and Heat Exchangers
In summary, the conversation discusses the rates of heat transfer from the top and bottom surfaces of a cubic block in stagnant air, and whether the exit temperature of the cold fluid can be greater than the exit temperature of the hot fluid in a heat exchanger. It is suggested that the rate of heat transfer may be affected by radiation, convection, and conduction, but it is ultimately uncertain. It is also noted that in a countercurrent heat exchanger, it is possible for the exit temperature of the cold fluid to be greater than that of the hot fluid.
AthlonFX
Hi folks,
Just a few general questions I have here.
1) The situation: A cubic block is taken from an oven and suspended so that both its top and bottom surfaces are exposed to the room air.
Would the rate of heat transfer from the top surface be greater, equal to, or less than the rate of transfer from the bottom surface? Why?
2) Is it possible for the exit temperature of the cold fluid to be greater than the exit temperature of the hot fluid in a heat exchanger? (simple scenario, let's assume it's a 1-1, and that both fluids are single phase fluids)
For 1) it's stagnant air, there is no movement of air. Of course, the only thing I could think of was that the top surface > bottom surface, due to natural convection. I'm just not sure if the same principle would apply on the bottom surface.
For 2) I didn't think it was possible if it was a cocurrent heat exchanger, since the log mean temperature difference would be undefinable. It could be applicable in a countercurrent heat exchanger though.
What are your thoughts?
The mechanisms are radiation, convection, and conduction. It sounds like conduction is zero. Radiation should depend on the temperatures of what the block is facing. The floor, ceiling and so on. Convection is complicated. You say stagnant air, but the block itself will heat the air and cause air currents. Bottom line, I don't know.
Yes, in a counter flow heat exchanger. LMTD can be calculated but you must be careful to subtract temperatures at the left/right sides, not the in/out temps.
Related to Regarding Heat Transfer and Heat Exchangers
1. What is heat transfer?
Heat transfer is the movement of thermal energy from one object or system to another. It can occur through three main mechanisms: conduction, convection, and radiation.
2. What is a heat exchanger?
A heat exchanger is a device that is used to transfer heat from one fluid or gas to another, without the two substances coming into direct contact with each other. It is commonly used in industries such as HVAC, chemical processing, and power generation.
3. How does a heat exchanger work?
A heat exchanger works by having two fluids or gases flow through separate channels that are in close proximity to each other. As one fluid or gas passes through, it transfers its heat to the walls of the channel, which then heats up the other fluid or gas as it passes through. This process continues until the desired temperature is reached.
4. What are the different types of heat exchangers?
There are several types of heat exchangers, including shell and tube, plate and frame, and double pipe. Each type has its own unique design and is suitable for different applications based on factors such as flow rate, pressure, and temperature.
5. What are some common uses for heat exchangers?
Heat exchangers are used in a variety of industries and applications, such as heating and cooling buildings, refrigeration systems, chemical processing, and power generation. They are also commonly used in everyday household appliances like refrigerators and air conditioners.
  • General Engineering
  • Mechanical Engineering
