Regarding Joule's gas expansion experiment
In summary, the original gas expansion experiment conducted by Joule shows that for an ideal gas, the temperature remains constant during free expansion due to the cancelling effects of "viscous heating." However, in reality, a change in temperature can occur due to intermolecular interactions. This is because the internal energy of a real gas is also affected by changes in specific volume. In the experiment, no work is done by the system on its surroundings and no heat transfer occurs, resulting in a net change of internal energy and thus no change in temperature for an ideal gas.
MichaelWiteman
Hi,
Joule's original gas expansion experiment is often presented like in the following link:
http://demonstrations.wolfram.com/JouleExperimentOnFreeExpansion/
The apparent lack of temperature change in this experiment is often used in textbooks to demonstrate that the energy of an ideal gas is only temp. dependent. It is, however, often mentioned that a non-negligible change in temp. for real gases occurs because of intermolecular interactions.
My question: wouldn't temp. change (decrease) also for the ideal case? After all the expanding gas will be doing work against the pressure that is being created in the right chamber? Am I missing something?Mike
Yes. Ordinarily you would expect the expanding gas to cool as it expanded. But, in this irreversible expansion, there is another physical mechanism at work. This is often referred to as "viscous heating," although there is minimal actual heat flow. A better term would be "viscous conversion of usable mechanical energy to internal energy. " This is the effect of viscous stresses that develop within the gas, which are determined not by the amount of deformation, but by the rate of deformation. For an ideal gas, the "heating" effect caused by viscous dissipation exactly cancels the cooling effect of the expansion, and the net result is no change in temperature.
In the experiment, there is no work done by the system (the total gas) on its surroundings because the combined chamber is rigid. And there is no heat transfer because the combined chamber is insulated. So, the overall change in internal energy is zero. For an ideal gas, the internal energy is a function only of temperature, so no change in internal energy means no change in temperature. For a real gas, the internal energy is also a function of specific volume, which decreases for the gas. So even though the internal energy is constant, a change in temperature occurs to offset the effect of the change in specific volume.
Chestermiller, thank you for your reply! I understand now were my logic broke. I was fixated on the the gas that is expanding in the left chamber and ignored the gas in the right chamber, which is being compressed as the system equilibrates, and thus the overall work in the system is zero. This should had been obvious since the system doesn't change volume. There is a similar experiment (Joule-Thomson) which was used to measure these small temperature changes in the compression/expansion of real gases. Thank you for your patience in explaining these basics!
Sincerely
Mike
Likes Chestermiller
The question: wouldn't temp. change (decrease) also for the ideal case? After all the expanding gas will be doing work against the pressure that is being created in the right chamber? Am I missing something?
My answer: yes the LHS-gas will do some work on the RHS-gas, but the RHS-gas will receive this work, with w+w=0. Together its only one system with some internal work done that has no effect on the internal energy, and (if n constant) T constant.
Related to Regarding Joule's gas expansion experiment
What is Joule's gas expansion experiment?
Joule's gas expansion experiment is a scientific experiment conducted by James Prescott Joule in the 1840s to determine the relationship between temperature and internal energy of a gas. It involved expanding a gas in a closed container and measuring the change in temperature.
What were the results of Joule's gas expansion experiment?
The results of Joule's gas expansion experiment confirmed the principle of conservation of energy and that the internal energy of a gas is directly proportional to its temperature. This led to the development of the first law of thermodynamics.
How did Joule's gas expansion experiment contribute to the field of thermodynamics?
Joule's gas expansion experiment provided evidence for the principle of conservation of energy and helped establish the first law of thermodynamics. It also contributed to the understanding of the relationship between temperature and internal energy of gases.
What were the limitations of Joule's gas expansion experiment?
One of the limitations of Joule's gas expansion experiment was that it assumed ideal gas behavior, which is not always the case in real-world situations. Additionally, the experiment did not account for any external factors, such as heat loss or gain, which could affect the results.
How is Joule's gas expansion experiment relevant today?
Joule's gas expansion experiment is still relevant today as it laid the foundation for the first law of thermodynamics and our understanding of the relationship between temperature and internal energy. It also continues to be used in modern experiments and research in the field of thermodynamics.
  • Other Physics Topics
  • Classical Physics
13K
75K
  • Thermodynamics
