Does SU(2) Commutativity Conflict with Its Non-Euclidean Structure?
In summary, the conversation discusses the relationship between the Lie algebra su(2) and the concept of smooth manifolds being locally euclidean. While su(2) has a non-trivial structure, the commutativity of orthogonal derivatives does not necessarily hold for all smooth manifolds, including su(2). This does not mean there is a mistake in the reasoning, but rather that the concept of smooth manifolds being locally euclidean does not fully apply to su(2).
Kontilera
179
24
Hello!
I thought I had a good picture of this stuff but now I suspect that I've mixed up things completely..
For su(2) we have:
[tex]f_{ab}\,^c = \epsilon_{ab}\,^c.[/tex]
Which means that, for the basis of our tangentspace we get:
[tex][\partial_a, \partial_b] = i \epsilon_{ab}\,^c\, \partial_c[/tex]
Where we can see that the space of linear approximations is closed under the Lie bracket product.
But what about the definition of a smooth manifold being locally euclidean?
For R^n we know that our orthogonal partial derivatives commute,
[tex]\partial_x\partial_y - \partial_y\partial_x = 0.[/tex]
Shouldnt we then expect the orthogonal derivatives to commute in su(2) as well?
This would mean that our structure constants are 0 both when a=b and when a is not equalt to b (for a orthonomal basis).
In other words.. it looks like the Lie algebra should be quite trivial.
This is of course not the case, but where does my mind make the mistake in this resoning?
Thanks!
// Kontilera
The Lie algebra elements are tangents along a path in the group. That means at its endpoint we are in a different tangent space albeit still isomorphic to ##\mathbb{R}^n##. But ##\partial_a\, , \,\partial_b## have three tangent spaces they arose from: starting point for ##a##, endpoint = starting point for ##b##, and endpoint of ##b##. The commutator measures how the endpoints of this path ##b\circ a## differs from that of ##a \circ a##. Since we have different tangent spaces at different points, we cannot expect that all this happens within one tangent space of the group. This is the difference between local and global behavior. Within a single ##\mathbb{R}^n## the paths ##b\circ a## and ##a\circ b## lead to the same endpoint, with changing tangent spaces this is no longer guaranteed.
Have a look on these insights:
https://www.physicsforums.com/insights/pantheon-derivatives-part-iv/https://www.physicsforums.com/insights/journey-manifold-su2-part-ii/
Hi Kontilera,
It seems like you are trying to understand the relationship between the Lie algebra su(2) and the concept of a smooth manifold being locally euclidean. The Lie algebra su(2) has a non-trivial structure, as you mentioned, and this can be seen from the fact that the structure constants are not all zero. This means that the Lie bracket product of two tangent vectors in su(2) is not always zero, and therefore the space of linear approximations is not closed under the Lie bracket product.
As for the definition of a smooth manifold being locally euclidean, this refers to the fact that a smooth manifold can be locally approximated by an euclidean space. This does not necessarily mean that all the properties of euclidean spaces also hold for smooth manifolds. In particular, the commutativity of orthogonal partial derivatives is a property of euclidean spaces, but it does not necessarily hold for all smooth manifolds.
In the case of su(2), the orthogonal derivatives do not commute, as you correctly pointed out. This does not mean that there is a mistake in your reasoning, but rather that the concept of smooth manifolds being locally euclidean does not directly apply to su(2). The structure of su(2) is more complex, and it cannot be fully captured by the concept of a smooth manifold being locally euclidean.
I hope this helps clarify your understanding. Keep exploring and asking questions!
FAQ: Does SU(2) Commutativity Conflict with Its Non-Euclidean Structure?
What is a Lie algebra?
A Lie algebra is a mathematical structure that studies the algebraic properties of vector fields and Lie brackets. It is a fundamental tool in the study of group theory and differential geometry.
How is a Lie algebra defined?
A Lie algebra is defined as a vector space equipped with a bilinear operation called the Lie bracket, which satisfies the Jacobi identity. This means that for any three elements in the vector space, the Lie bracket of the first two elements with the third element is equal to the sum of the Lie bracket of the first element with the second element and the Lie bracket of the second element with the third element.
What are some applications of Lie algebras?
Lie algebras have numerous applications in physics, specifically in the study of symmetry and conservation laws. They are also used in the study of differential equations, topology, and complex analysis.
How do Lie algebras relate to Lie groups?
Lie algebras and Lie groups are closely related, with Lie groups being a continuous version of Lie algebras. A Lie algebra can be seen as the tangent space of a Lie group at its identity element. The Lie bracket operation on the Lie algebra corresponds to the group operation on the Lie group.
Are there real-world examples of Lie algebras?
Yes, Lie algebras have been used to model various physical systems, such as the motion of a rigid body, the behavior of a pendulum, and the rotation of a magnetic dipole. They are also used in engineering for control systems and robotics.
