Regarding MSc and PhD research areas
In summary, it is possible for a CS student to work with numerical methods in MSc and PhD level, but it will require some catching up. If you complete your MSc in CS (optimization), there is a chance of you being able to apply for a PhD (on other universities) to study numerical methods (usually located under maths).
lonatico
Hi,
I'm about to start my MSc in Computer Science studying "Combinatorial Optimization", which was already the theme of my undergraduation thesis. I like the field and the research, but I'd rather prefer working with numerical methods and techniques. The problem is my current university has a very weak research on that, and it is located in the maths departament.
My two questions are:
1) Is it possible for a CS student to work with numerical methods in MSc and PhD level?
2) If I complete my MSc in CS (optimization), is there a chance of me being able to apply for a PhD (on other universities) to study numerical methods (usually located under maths)? I have heard some people talking about the importance of "breeding" in academic research;
I know it usually depends on the university, but the questions are more on a "is it likely" fashion.
lonatico said:
Hi,
Yes, but depending on the topic and your knowledge, you might have some catching up to do.
Yes, if you get good grades and good recommendations from professors, there will be no problem.
Thanks for the reply :)
So, my knowledge is not that wide. I know the basics about numerical methods: integration (Trapezium and simpson), interpolation (Lagrange, nevile, bezier and splines), zeros of functions (bissection and Newton), ODE (runge kutta). However, I don't have a deeper knowledge on math fundation such as Differntial Equations (all I know is because of the RK method and of image processing, i.e., only a very superficial knowledge), or numerical analysis, which as far as I know is important for the area. Though the classes, implementing and reading about such field is very entertaining to me. I would like to work with more math than CS as to say.
Regarding my grades, throughout my CS degree I have been a B+~A average student. About the recomendation letter, does it have to be from people working in the numerical methods field, or can it be, say, from my current advisor (combinatorial optimization)?
I'm very aware that my knowledge has lots of gaps, so being realistic, would it be hard to get accepted in a MSc or Phd? And would it be a better choice to perhaps drop my current MSc and try another program on numerical methods instead (risking being half or one year delayed)?
You have some catching up to do. But nothing too much. I would start reading up on numerical methods as soonas you can.
Your current advisor is ok as a recommendation. But you will also want a letter from somebody in numerical methods for your PhD.
I think you have a chance. But to drop out of your Msc for that? I wouldn't do it. Well, you know the risks, it's up to you. It's not like you can't get into a PhD in numerical if you do this masters.
FAQ: Regarding MSc and PhD research areas
What is the difference between MSc and PhD research areas?
The main difference between MSc and PhD research areas is the level of depth and complexity. MSc research areas typically involve conducting research and experiments under the guidance of a supervisor, while PhD research areas require original and independent research, often resulting in a dissertation or thesis.
How do I choose a research area for my MSc/PhD?
Choosing a research area for your MSc or PhD should involve careful consideration of your interests, skills, and future career goals. It is important to consult with your supervisor and do thorough research on the available options before making a decision.
Can I change my research area during my MSc/PhD program?
Yes, it is possible to change your research area during your MSc or PhD program. However, this decision should be made carefully and in consultation with your supervisor to avoid any delays in your progress or conflicts with your program requirements.
How long does it take to complete research in an MSc/PhD program?
The duration of research in an MSc or PhD program can vary depending on the specific research area and the individual's progress. On average, an MSc program can take 1-2 years and a PhD program can take 3-5 years to complete the research component.
Are there any funding opportunities for MSc/PhD research areas?
Yes, there are various funding opportunities available for MSc and PhD research areas, including scholarships, grants, and assistantships. It is important to research and apply for these opportunities early on in your program to increase your chances of receiving funding.
