Regarding the complex solutions of a torus
In summary: Yes, it is reasonable to think of it this way. In fact, the complex solutions for z represent the points on the torus that lie outside the z-axis. This is because when z is imaginary, it means that the point is not on the torus, but rather on the "imaginary torus" that is created when translating the torus along the x or y axis. So, in summary, the complex solutions for z in the torus equation are important in describing the points that lie outside the z-axis on the torus.
Philip
The equation for a torus defined implicitly is,
$$(\sqrt{x^{2} + y^{2}} -a)^{2} + z^{2} = b^{2}$$
When solving for the z-axis in the torus equation, we get complex solutions, from the empty intersection:
$$z = - \sqrt{b^{2} - a^{2}}$$
$$z = \sqrt{b^{2} - a^{2}}$$
I was told by someone that these solutions have nothing to do with the initial torus. What's the reasoning here?
It would seem that the real set of points on the torus would still be an important part of the complex solutions. Even though z makes no intercepts initially, it will if translating the torus along x or y, by the value of plus or minus 'a' . Doing so will cancel the complex component, bringing two solutions into the real plane.Another question I had was regarding the solutions of z, and whether they can simplify/reduce any more than,
$$z = - \sqrt{(b-a)(b+a)}$$
$$z = \sqrt{(b-a)(b+a)}$$
More specifically, can we get the expected complex conjugates out of this expression?
Mathematics news on Phys.org
What you've said doesn't make sense. Consider the torus centered at ##h, k##; translating the torus doesn't change the solutions for ##z## obtained at the central axis of the torus ##(x, y)=(h, k)##.
They simplify precisely when ##a=b## or ##a=-b##, in which case the torus becomes a horned torus.
What complex conjugates? You never mentioned anything of the sort. Could you elaborate?
suremarc said:
What you've said doesn't make sense. Consider the torus centered at h,kh, k; translating the torus doesn't change the solutions for zz obtained at the central axis of the torus (x,y)=(h,k)(x, y)=(h, k).
Thanks for your reply! Assuming a > b, I'm considering the ring torus. Placed at origin, the z-axis will sit in the center of the hole. Translating the torus by the value of 'a' , along x or y, will make z intersect the ring, making two points.
More precisely,
translate by 'a' along x (where this could be +a , -a ,along x or y) :
$$(\sqrt{(x-a)^{2} + y^{2}} -a)^{2} + z^{2} = b^{2}$$
set x=0 , y=0 , solve for z:
$$(\sqrt{(0-a)^{2} + 0^{2}} -a)^{2} + z^{2} = b^{2}$$
$$(\sqrt{(-a)^{2}} -a)^{2} + z^{2} = b^{2}$$
$$(\sqrt{a^{2}} -a)^{2} + z^{2} = b^{2}$$
$$(a -a)^{2} + z^{2} = b^{2}$$
$$z^{2} = b^{2}$$
$$z = \sqrt{b^{2}} , z = -\sqrt{b^{2}}$$
where z has two real solutions,
$$z = b , z = -b$$
Coincidentally, from a naive 1D point of view in the z-axis, adjusting the major diameter 'a' gradually to zero is visually indistinguishable from translating by 'a' . They both would look the same!
About the complex conjugates, here's what I've been thinking. When a > b , and setting a=0 will make real solutions of b , then wouldn't it mean 'a' is the imaginary part? It does describe the size of the ring torus hole, which is an empty set of points.
Similarly, when we graph a parabola that sits above the x-axis, in the +y half, the quadratic equation has two complex solutions. X makes a completely empty intersection. The set of points of the parabola sit "outside" the x-axis, and a complex conjugate solution is the algebraic way of defining it.
Considering that, is it reasonable to assume that the set of points on the torus, that lie "outside" the z-axis, can also be described as complex conjugate solutions?Going back to $$z = - \sqrt{b^2 - a^2} , z = \sqrt{b^2 - a^2}$$
when a > b for a ring torus, we get square root of a negative number, which yields an imaginary number. If a = 0 , we get square root of a positive number, yielding a real number. So, if both are working together, since both would not equal zero, wouldn't this be a complex conjugate, with real and imaginary?
More precisely,
$$z^{2} = b^{2}$$
$$z = b , z = -b$$
That is correct--but what does it have to do with the torus?? I still don't understand.
Translating a quadratic on the ##y##-axis has a very simple effect indeed, easily described via the quadratic formula.
The equation for a torus however is quartic. It is only when you hold two of ##x, y, z## constant that the equation reduces to a quadratic--in that case, we are restricted to a minuscule portion of the full solution set,
suremarc said:
It is only when you hold two of x,y,zx, y, z constant that the equation reduces to a quadratic
Yes, that's a good point. It does reduce to a product of two quadratic equations for a circle. I guess what I'm trying to understand, is by considering this 2D solution of a torus:
https://www.desmos.com/calculator/qmk3bia8ia
If solving for x, can we say these circles lie in the complex plane, much like a parabola that makes no intersection? If so, what would those solutions look like, other than ##x = -\sqrt{b^2-a^2} , \sqrt{b^2-a^2}## ? Is it possible to get a more obvious-looking complex conjugate, like ##(x-1-i2)(x-1+i2)## ?
Well, after a LOT of playing around, experimenting, and searching for some kind of meaning here, I finally found it. The circles are in the complex plane, and the roots of z, as stated above, are the simplest possible expression, other than something like ##z = -\sqrt{(b-a)(b+a)} , z = \sqrt{(b-a)(b+a)}## . I needed to see where the points on the circle were, that correspond to what the imaginary value will be. It's a product of four of them, as the points that lie on the y-axis.
Related to Regarding the complex solutions of a torus
What is a torus and how is it related to complex solutions?
A torus is a donut-shaped geometric object that can be defined by a set of parametric equations. It is related to complex solutions because the parametric equations of a torus involve complex numbers.
What are the complex solutions of a torus used for?
The complex solutions of a torus are used in many scientific and mathematical applications, such as in fluid dynamics, electromagnetism, and computer graphics.
Are there any real-world examples of toroidal structures?
Yes, there are many real-world examples of toroidal structures, such as the shape of a donut, a life preserver, or the rings of Saturn.
How are the complex solutions of a torus calculated?
The complex solutions of a torus can be calculated using the parametric equations of the torus, which involve the use of complex numbers and trigonometric functions.
What is the significance of complex solutions in understanding toroidal structures?
The complex solutions of a torus provide a deeper understanding of the geometry and behavior of toroidal structures, and allow for more accurate and complex mathematical models to be developed.
  • General Math
  • General Math
  • General Math
