Regarding the radius in the orbital velocity
In summary: Equations is how relations are stated in physics.To understand gravitational Potential energy without using math, picture dropping a steel ball bearing on a plate of glass. Not a very heavy ball bearing, just a small one you could hold in your fingertips. If you drop it from a couple of inches, the glass vibrates, and you hear a sharp noise. Drop it from a couple of feet, and the noise will be much louder, and the bearing Will bounce. Drop it from 8 to 10 feet, and will break the glass. In this scenario, the ball bearing has potential energy because it has the ability to do work on the glass (vibrate it, make a loud noise, or break it). When you release
DLeuPel
56
Would the velocity of a body which is orbiting another body change due to its radius to the center of gravity? If so, why? A body which moves passed a planet and starts orbiting it should have the same velocity it had before ,regarding the fact that it is orbiting a planet. Also, gravity isn’t really a force but the geometrical deformation of the fabric of space time. So really is like if you were riding your car in a tilted road so the car curves itself without the need of any forces acting upon it. The more the gravity the more the road is titled.
Yes, because of conservation of energy. Gravitational potential energy is negative. Its magnitude increases with decreasing radius. The orbiting body's kinetic energy must increase in order to keep the total energy constant. You can observe this with bodies in elliptical orbits: they move fastest at the closest point to their central body, and slowest at the farthest point.
Oh, isn't it ?
What is the gravitacional potencial energy? I’m not asking for the equations i just want to know what relation does gravity have with energy.
The force of gravity is defined as F=(Gm1m2)/r^2. You've probably seen it modeled as a fabric/grid.
GPE is inversely related to the radius and directly proportional to mass and gravitational constant.
Only according to Newton’s Law of Gravitation which is wrong. But we use his equations due to the fact that they are more simple to use and the solutions that they give us are very close to the real solution to gravity related problems. The accepted model of gravity is that of Einstein’s famous General Relativity. In which gravity is not a force but the presence of matter bending a fabric. Just like applying pressure to your bed and see how it sinks with your fist. Here she a link to an easy to see representation of gravity
Energy is the potential to do work. Gravitational potential energy is therefore the ability for gravity to do work. In this case, applying a force to accelerate an object approaching another object.
Newton's Law of Gravitation is not "wrong" in a binary sense. It is highly accurate for most everyday purposes including the scenario you describe in this thread.
Likes BvU
DLeuPel said:
The accepted model of gravity is that of Einstein’s famous General Relativity. In which gravity is not a force...
It's not an interaction force in GR, but can still be modeled as an inertial force, based on which potential energy can be defined.
DLeuPel said:
...but the presence of matter bending a fabric. Just like applying pressure to your bed and see how it sinks with your fist. Here she a link to an easy to see representation of gravity
A very misleading analogy, as explained here:
https://www.physicsforums.com/threa...the-force-of-gravitation.760793/#post-4791624
See this for a more relevant analogy:
https://www.physicsforums.com/threads/gravity-and-curved-space.917934/#post-5786330
To understand gravitational Potential energy without using math, picture dropping a steel ball bearing on a plate of glass. Not a very heavy ball bearing, just a small one you could hold in your fingertips. If you drop it from a couple of inches, the glass vibrates, and you hear a sharp noise. Drop it from a couple of feet, and the noise will be much louder, and the bearing Will bounce. Drop it from 8 to 10 feet, and will break the glass. As you raise the bearing higher above the glass, you give it more potential to do work on the glass. When you release the bearing, that potential energy is converted into kinetic. As the bearing gets lower and lower, it’s speed increases. That is to say, it’s potential energy is converted into kinetic energy.
In orbital mechanics, this relationship works the same way. It is most easily seen in highly elliptical orbits. As the object “falls” closer to the center of gravity, it gains speed. After passing its closest point, it begins climbing again, and slowing down.
To answer the why question directly. Because, the curvature of spacetime outside a spherical object is described by:
##ds^2 = -(1- \frac{2M}{r})dt^2 + (1- \frac{2M}{r})^{-1}dr^2 + r^2(d\theta^2 + \sin^2 \theta d\phi^2)##
Which leads to the "energy" equation of motion:
##E = \frac12(\frac{dr}{d\tau})^2 + V(r)##
Where ##V(r)## is the effective potential. This is the same equation as in Newtonian gravity, but in GR this potential has an additional term. For planetary orbits about the Sun, for example, this additional term is negligible, so we have a valid Newtonian approximation.
You may be thinking (from your rubber sheet or road analogies) that space itself has a defined shape and compels an object to move in a specific physical path. One problem with these analogies is that it is spacetime that is curved. So, one of the dimensions on your rubber sheet should be the time dimension, which is not so easy to visualise.
Because spacetime (space and time) are curved, the notion of "constant speed" is not so clear cut. We (as outside observers, using our system of coordinates - centred on the Sun, say) measure a change in coordinate velocity - that is not measurable as an acceleration by the orbiting body itself.
Related to Regarding the radius in the orbital velocity
1. What is the radius in the orbital velocity?
The radius in the orbital velocity refers to the distance between the center of mass of an object and the center of the orbit it is following. It is an important factor in determining the speed at which an object travels in its orbit.
2. How does the radius affect the orbital velocity?
The radius and the orbital velocity are directly related through the law of universal gravitation. A larger radius results in a slower orbital velocity, while a smaller radius results in a faster orbital velocity.
3. Can the radius change during an orbit?
Yes, the radius can change during an orbit due to external forces such as gravitational pull or drag from the atmosphere. This can cause changes in orbital velocity as well.
4. What is the formula for calculating orbital velocity?
The formula for orbital velocity is v = √(GM/r), where G is the gravitational constant, M is the mass of the central body, and r is the radius.
5. How is the radius in the orbital velocity related to the size of the object?
The radius in the orbital velocity is not directly related to the size of the object. It is primarily determined by the mass and distance of the central body, and the mass and distance of the orbiting object. However, a larger object with a greater mass may require a larger radius to maintain a stable orbit at a certain velocity.
  • Mechanics
9K
  • Mechanics
