Regions of the complex plane - finding the locus
In summary, the given locus is a hyperbola with asymptotes at y=±√(7)x/3 and x≤-(3/2). The steps taken to simplify the equation and find the locus involve using the properties of complex numbers, specifically the modulus or absolute value, to rewrite the equation in a familiar form. It is important to understand the notation in complex numbers to avoid confusion.
autodidude
333
Find the locus defined by [tex]|z-2|-|z+2|=3[/tex]
The given example rewrites the left hand side as:
[tex]\sqrt{(x-2)^2+y^2}-\sqrt{(x+2)^2+y^2}[/tex]
1) When they rewrite it as that, they square it and square root it right? Why isn't it squaring the whole expression and rooting it (isn't that the rule?)
i.e.
[tex]\sqrt{((x-2)+y)^2}-\sqrt{((x+2)+y)^2}[/tex]
2) Why does the 'i' disappear?
Then they move the second expression to the right hand side, square both sides and complete the square for bot sides, square both sides again and they end up with the locus being a hyperbola with asymptotes at y=±√(7)x/3 and x≤-(3/2)
They don't explain the reason for taking these steps (terse book) - is it just standard procedure for these type of questions? To simplify + complete the square until you get a familiar looking equation?
Mathematics news on Phys.org
i.e.
You should read a little about "complex numbers", "absolute value of complex numbers"
or "module of a complex number" .It's pretty easy and this will clear out your doubts.
DonAntonio
^ Ok, will do
From what I understand, the modulus of a complex number is its distance from the origin, [tex]|z| = \sqrt{(x^2+y^2}[/tex], so...for [tex]|z-2| = |(x-2)+yi|[/tex], the modulus bars just denote the distance, which justifies the next part (second equation in my original post)
Why did they still write the i though? Sorry, I forgot to show that they also wrote [tex]|x+yi-2|-|x+yi+2|=3[/tex]
And I still don't understand how they figured how all the steps to 'reduce' the equation into one where they could find the locus
By the way, when I asked why the 'i' disappeared, it was because they'd shown that [tex]|z-2||/tex] was equivalent to |(x-2)+yi| - if they
But if you read the WHOLE chapter on complex numbers, then it becomes clear that when taking the module one squares the real and
imaginary parts, sum them and take the square root of it. Not "i" involved...Of course, this is due to the fact that we can
identify the complex number with real points on the plane xy (or [itex]\mathbb R^2[/itex] , if you will), so the module is, as you
mention, just the distance from the origin of a point on the plane = a complex number.
DonAntonio
So when they change |x+yi-2| to √((x-2)^2+y^2), they're only looking at the points on the plane...if |x+yi-2| already denotes distance, why write 'yi'?Why not just 'y'?
And I'm just being pedantic for this...the stuff that I can't find any good resources on is finding the locus defined by it
As you wrote in your first post, and after we understood (??) how things work, you have [tex]\sqrt{(x-2)^2+y^2}-\sqrt{(x+2)^2+y^2}=3[/tex] so passing one of the roots to the other side and squaring one gets [tex](x-2)^2+y^2=9+(x+2)^2+y^2+6\sqrt{(x+2)^2+y^2}[/tex]
Now some algebraic hokus-pokus and one gets [tex]-8x-9=6\sqrt{(x+2)^2+y^2}\Longrightarrow 64x^2+144x+81=36(x+2)^2+36y^2\Longrightarrow[/tex][tex]28x^2-36y^2-63=0\Longleftrightarrow \frac{x^2}{\left(3/2\right)^2}-\frac{y^2}{\left(\sqrt{7}/2\right)^2}=1[/tex] and so this is a hyperbola
DonAntonio
Pd. Check the above calculations. It'd not be that strange if there's some mistake.
It's not just pedantics, it's important to understand what the notation is saying so you don't get confused later.
Let's consider the case when x=1 and y=1.
[tex] |1+1i-2| = |-1+i| = \sqrt{(-1)^2+1^2} = \sqrt{2}[/tex]
If we just didn't write in yi and wrote in simply y instead, then we are taking the absolute value of a different number
[tex] |1+1-2| = |0| = 0[/tex]
It might seem obvious when the variables are left in that x and y are referring to the real and imaginary parts of a complex number, but if you don't include the i then y is not referring to the imaginary part of a complex number anymore
@DonAntonio: How do you know to pass one square root to the other side and square? Basically I want to know how you know which algebraic 'hocus-pocus' to do to get find the locus . My book doesn't explain any of these, it just shows the steps without explaining why they took took the steps I did (described in my initial post, and it seems to be the steps you've taken as well)
@Office_Shredder: So the point of the i there is to just indicate that you're referring to the imaginary part, and that goes when you take the modulus you're taking the magnitude and it's obvious that it's two different parts?
Moving one square root to the other side wasn't necessary. What we want to do is get rid of all the square roots, and that involves squaring of course. But when two surds are present, you'll need to square things twice.
For example, if we have something of the form
[tex]\sqrt{a}+\sqrt{b}=c[/tex]
Then squaring will yield
[tex]a+2\sqrt{ab}+b=c^2[/tex]
And as you can see, we still have a surd to deal with. Even if we moved one or both of the terms to the other side at the start and squared, we'd still have surds to deal with.
Anyway, from this point we will move everything that is not a square root to one side, leaving the square root alone
[tex]2\sqrt{ab}=c^2-a-b[/tex]
Now we can square again and finally be rid of the surd.
^ So the goal is to get rid of the square roots, and once that's done, you should have some equation for a locus?
Yes, but let's be clear about this. The form [tex]\sqrt{a}+\sqrt{b}=c[/tex] is already an equation of the locus that describes the original question, but we're just trying to convert it into a form that makes more sense to us.
And that's what DonAntonio has done.
Can the forms be any sort of random shape on the plane? Or is it just circles, ellipses, hyperbolas and such?
It will depend on the equation you use. Different equations lead to different geometric representations and it's not a specific thing to answer unless you specify the form of the identity you are using (i.e. blah1 = blah2).
So they're just like...'normal' equations then? (in the sense that you can have any sort shape)
Yeah pretty much. You could end up having an explicit form or an explicit form. Implicit forms in general allow you to have very complex and general kinds of structures, but if you are only dealing with functions involving x and y (even implicit), the output will still be a curve although it may not technically be a function per se.
You will end up with a line that takes on a trajectory of some sort and if you only have the moduli of complex numbers and functions involving either only a constant functions of x,y or both on the RHS side, then you will always get a line that is deformed in some way in your normal 2D space.
If you wanted to find the one dimensional form of the line, you would need to parameterize the line to getting x(t) and y(t) where t is your parameter (often from -infinity to +infinity) but this is far from easy for the general case.
^ thanks, I'm still trying to trying to understand what the difference between a parametric equation and a regular (algebraic?) equation is, parameter and variable...will probably be my next question if I can't figure it out
FAQ: Regions of the complex plane - finding the locus
1. What is the complex plane?
The complex plane is a mathematical concept used to visualize complex numbers. It is a 2-dimensional plane with a horizontal real axis and a vertical imaginary axis, where the complex number a + bi is represented by the point (a,b).
2. What is a locus on the complex plane?
A locus on the complex plane is a set of points that satisfy a specific condition or equation. In other words, it is the path traced by a point that moves according to a given rule or constraint.
3. How do you find the locus on the complex plane?
To find the locus on the complex plane, you first need to determine the rule or condition that the points must satisfy. This could be an equation, inequality, or geometric property. Then, you can plot points on the complex plane and see which ones satisfy the rule, thus forming the locus.
4. What are some common types of loci on the complex plane?
Some common types of loci on the complex plane include circles, ellipses, hyperbolas, and parabolas. These can be formed by different equations or geometric rules, and they have distinct shapes and properties.
5. Why are loci on the complex plane important?
Loci on the complex plane are important because they allow us to visualize and understand complex numbers and their relationships. They also have important applications in fields such as engineering, physics, and economics, where complex numbers are commonly used to model and solve problems.
