Regression analysis: logarithm or relative change?
In summary, the dependent variable in regression analyses using the logarithm of the closing price as the dependent variable provides a better result than when the relative change is used.
monsmatglad
76
Hi. I am currently studying the market for equity options and the use of these to predict stock return around company earnings announcements. The dependent variable in my regression analyses have been the relative change in stock price or log-return from the day before the announcement to closing price on announcement day. However, would it be reasonable to instead/also run regressions using the logarithm of the closing price itself as the dependent variable. Then the independent variables would still show if they have a tendency to pull the price up or down on the day of the earnings announcement, although there would be no data involved actually showing relative change. Running a few short tests, shows that the log-alternative provides more significant relations and a greater R^2 than when using the relative change as the dependent variable. Am I completely mistaken?
Mons
One thing that may be of concern, suppose you predict a value for the logarithm of the stock price and it is a little bit off from the log of the actual price. So it looks like you have a pretty good model. But a little bit in log scale can be a lot in actual stock values.
Say we are talking log (base 10). If you predict the log is 2.01, but say the log of the actual is 2.00, you think it is only 0.5% off - not bad. But the actual stock prices are $100, while the predicted is $102.33 (2.33% off). As the errors get a little larger, you'll see the price variations increase exponentially.
Likes Stephen Tashi
You need a stationary series to do decent statistical tests and log prices / returns is the standard method. Regressions on a non-stationary series will show artificially high R^2. In general, you should view any R^2 > around 0.4 with deep suspicion unless is it something trivial, like regressing equity mutual fund returns against a stock index. The beta T-stats are the important variable. For this you are interested in log returns in excess of the market - need to strip out the market return to do this properly
Likes scottdave
Related to Regression analysis: logarithm or relative change?
1. What is regression analysis and how is it used?
Regression analysis is a statistical method used to examine the relationship between a dependent variable and one or more independent variables. It is used to understand and predict the effect of changes in the independent variables on the dependent variable.
2. What is the difference between using a logarithm and relative change in regression analysis?
The difference between using a logarithm and relative change in regression analysis lies in the interpretation of the results. Logarithm transformation is used to normalize the data and make it easier to interpret the relationship between variables. Relative change, on the other hand, measures the percentage change in the dependent variable for a given change in the independent variable.
3. When should I use a logarithm in regression analysis?
A logarithm should be used in regression analysis when the data is skewed or the relationship between the variables is non-linear. Logarithm transformation helps to make the data more normally distributed and can improve the accuracy of the regression model.
4. Can I use both logarithm and relative change in the same regression model?
Yes, it is possible to use both logarithm and relative change in the same regression model. This can be helpful in cases where the relationship between the variables is complex and cannot be accurately captured by using just one transformation.
5. How do I interpret the results of a regression analysis using logarithm or relative change?
The interpretation of the results will depend on which transformation was used. When using a logarithm, the coefficient represents the percentage change in the dependent variable for a one-unit increase in the independent variable. With relative change, the coefficient represents the percentage change in the dependent variable for a one percentage point increase in the independent variable.
  • Mechanical Engineering
