Regression for a first order system
In summary, the conversation is about carrying out a regression for diameter of a part, with the equation Diameter = -0.0531052 + 0.0443237 * exp (-0.0103633 * 'Time elapsed'). The question is to find the value for time elapsed when the diameter is -0.052, and an explanation of the steps is requested. The suggested approach is to solve for t, using the natural logarithm.
Smitha921
I am carrying out a regression for diameter of a part
if diameter is -0.052
then can some one please calculate the value for time elapsed
would you please explain the steps
Hello @Smitha921,
:welcome:
Welcome to PF!
We won't do your work for you. You'll have to do that yourself.
But we will try to help you along if you get stuck.
You have an equation. Solve for t. Hint: The solution involves, in part, the natural logarithm.
Related to Regression for a first order system
1. What is a first order system in regression?
A first order system in regression refers to a system where the dependent variable is influenced by only one independent variable. This means that the relationship between the dependent and independent variable can be represented by a straight line on a graph.
2. How do you perform regression for a first order system?
To perform regression for a first order system, you need to collect data for the dependent and independent variables, plot them on a scatter plot, and then use a statistical software or calculator to find the equation of the line of best fit. This equation can then be used to make predictions or analyze the relationship between the variables.
3. What are the assumptions of regression for a first order system?
The assumptions of regression for a first order system include linearity, normality, homoscedasticity, and independence. Linearity refers to the relationship between the variables being a straight line. Normality means that the data should follow a bell-shaped curve. Homoscedasticity means that the variance of the data should be constant. Independence means that the observations should not be influenced by each other.
4. How do you interpret the results of regression for a first order system?
The results of regression for a first order system are typically presented in the form of an equation, which includes the slope and y-intercept of the line of best fit. The slope represents the change in the dependent variable for every unit change in the independent variable. The y-intercept represents the value of the dependent variable when the independent variable is equal to zero. Additionally, the coefficient of determination (R-squared) can be used to determine the strength of the relationship between the variables.
5. What are some common uses of regression for a first order system?
Regression for a first order system is commonly used in data analysis and prediction. It can be used to analyze the relationship between variables and make predictions about future values of the dependent variable based on the independent variable. This type of regression is also frequently used in fields such as economics, social sciences, and business to understand and quantify relationships between variables.
9K
