Regressions without calculator
  • Thread starter jmsdg7
  • Tags
    Calculator
In summary, the conversation is discussing the process of finding a linear equation using more than two points and higher degrees without the use of a calculator. The simplest method mentioned is the Least Squares, which involves finding the parameters that minimize the difference between the given points and the desired function. A more elaborate explanation will be provided in the future. The process involves finding the inverse of a matrix and using it to solve for the parameters a and b. For higher order polynomials, the process involves substituting different values for x and b. The simpler equations for finding the slope and y-intercept are also mentioned.
jmsdg7
im a senior in high school taking ap calculus, I've done regressions here and there with the calculator but i was wondering how do do it without the calculator, i obviously know how to get a linear equation out of 2 points, but how is it done with more points and higher degrees?
i understand that you need 2 points for a line, 3 for a quadradic, 4 for a cubic and 5 for a quartic but i was hoping someone could show me how it is done.:confused:
Mathematics news on Phys.org
The simplest method i know is the Least Squares, there are many others.
I can show you the general form for any number of points and any type of equation, but it takes a little hard work and algebra.
In short therms, you have to find the parameters that minimize the difference [tex]\sum [f(x)-q(x)]^2[/tex], where [tex]q(x)[/tex] is the function you want to minimize, and [tex]f(x)[/tex] are the points you are given.
I'll try to post something more elaborate this week.
Let the model be y = a + b x + u. Parameters of the model are a and b, u is the error term.
Variables y, x (and u) are each N-by-1 vectors.
Let X = [1 x] be the N-by-2 matrix. The first column of X is a vector of 1's. The second column of X is identical to vector x.
Let Z be the inverse of X'X. Z is a 2-by-2 matrix.
Then we can write [a b]' = ZX'y, which is 2-by-1. Parameter a is the first (top) element of ZX'y. Parameter b is the second element of ZX'y.
For higher order polynomials, substitute [x x^2 x^3 ...] for x, and [b1 b2 b3 ...] for b.
Of course, for simple regression, the matrix approach mentioned above is equivalent to the following equations:
The slope is given by
[tex]
b = \frac{\sum{(x-\bar x)(y - \bar y)}}{\sum (x-\bar x)^2}
[/tex]
and the y-intercept is given by
[tex]
a = \bar y - b \bar x
[/tex]
As a scientist, it is important to understand the fundamentals of mathematical concepts. While using a calculator can be helpful in performing regressions, it is also important to understand the underlying principles and methods behind them. In order to perform regressions without a calculator, you can use the method of least squares. This involves finding the line or curve of best fit that minimizes the sum of the squared distances between the data points and the line or curve.
For linear regression with more than two points, you can use the formula y = mx + b, where m is the slope and b is the y-intercept. To find the values of m and b, you can use the least squares method by setting up a system of equations using the given data points. This can be done by finding the sum of the x-values, the sum of the y-values, the sum of the x-values squared, and the sum of the x-values multiplied by the y-values. These values can then be used to solve for m and b, which will give you the equation for the line of best fit.
For higher degree regressions, such as quadratic, cubic, or quartic, the process is similar. You will need to set up a system of equations using the given data points and the coefficients of the polynomial. These equations can then be solved using techniques such as substitution or elimination to find the coefficients and ultimately the equation for the curve of best fit.
It is important to note that performing regressions without a calculator may be more time-consuming and prone to human error. However, it is a valuable skill to have and can help deepen your understanding of the mathematical concepts involved. I suggest practicing with different sets of data and using online resources or textbooks for further guidance and examples. Good luck with your studies!
FAQ: Regressions without calculator
What is a regression without calculator?
A regression without calculator is a statistical method used to analyze the relationship between two or more variables. It involves finding the best-fit line or curve that represents the relationship between the variables.
Why would someone use a regression without calculator?
A regression without calculator is often used when the data set is small and simple enough to be analyzed without the use of a calculator. It is also useful when performing quick analyses or when a calculator is not available.
What are the steps involved in performing a regression without calculator?
The steps involved in performing a regression without calculator include: 1. Plotting the data points on a scatter plot 2. Visualizing the trend and determining the type of relationship between the variables 3. Calculating the slope of the best-fit line or curve 4. Calculating the intercept of the best-fit line or curve 5. Writing the equation of the best-fit line or curve 6. Analyzing the accuracy of the regression by calculating the coefficient of determination.
What are the limitations of using a regression without calculator?
One limitation of using a regression without calculator is that it may not be as accurate as using a calculator, especially when dealing with complex data sets. It also does not allow for advanced statistical analysis such as hypothesis testing or confidence intervals.
What are some examples of when a regression without calculator would be useful?
A regression without calculator would be useful in situations such as analyzing the relationship between the amount of time spent studying and the grade on a test, or the relationship between the number of hours worked and the amount of money earned. It can also be used to predict future values based on past data.
