Comp Sci Regular Expression in Theory of Automata and Computation
The discussion centers on the validity of a regular expression meant to capture strings with specific properties regarding the letters 'a' and 'b'. Participants express concern that the provided regular expression allows invalid strings, such as "aabbbbaa," which contains a block of four consecutive 'b's. There is also debate over two proposed regular expressions, with one participant asserting they are not equivalent due to differing accepted string lengths. The complexity of the syntax used is noted as being non-standard compared to typical Perl compatible regular expressions (PCRE). Clarification from a teaching assistant or instructor is recommended for resolving these issues.
Crystal037
Find the regular expression to accept strings following the conditions given below:
(i)strings of a's and b's such that every block of 4 consecutive symbols contains at least 2 a's
(i)strings of a's and b's whose length is either even or a multiple of 3 or both
I will use E to denote epsilon that is empty string
In first part,since every block of 4 consecutive symbol contain at least 2 a's
The answer in notes is given
(aa(a+b)(a+b)+a(a+b)a(a+b)+a(a+b)(a+b)a+(a+b)aa(a+b)+(a+b)a(a+b)a+(a+b)(a+b)aa)+
But this wont be true since if we choose aabbbbaa which is possible according to the above regular expression, it wont be correct since there's a block with 4 consecutive b's
In 2nd part,
I have come up with 2 answers, are both of these same
((a+b)2)*+((a+b)3)*
and ((a+b)2)**((a+b)3)*
In 2022 when we use the term "regular expression" most people think of "Perl compatible regular expressions" (PCRE); the syntax you are using is not PCRE, nor is it the same as anything else I have seen before. In particular it is more complicated than we usually use in the theory of automata.
Anyway, for your answers:
(i) I agree that the given expression admits aabbbbaa; either the question is poorly worded or the answer is wrong
(ii) Assuming (a+b) means "a or b" and R2 means "RR" then (a+b)2 admits "aa", "ab", "ba" or "bb" which is not going to help.
Likes FactChecker
This would give string of length 2, I have used a * kleen star above the whole thing, which will give multiples of 2
$$((a+b)^2)^*+((a+b)^3)^*$$
$$((a+b)^2)^*((a+b)^3)^*$$
If the above is what you meant, the two aren't equivalent, because, as an example, the second one accepts strings of length 5, or 7, or ##2k+3j## in general.
I agree with pbuk that the first question is either worded in a misleading way or the solution in the notes is incorrect. I think they mean each block $$x_{4i}x_{4i+1}x_{4i+2}x_{4i+3}$$ contains 2 a's.
ok and for the first part for the given question what should be the correct regular expression
It wouldn't help to just give you an answer.
If there is a TA or instructor you can contact, I would ask them for clarification.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
