MHB Regular expression to NFA-confusing regular expressions-:
The discussion centers on converting the regular expression R=(01+010)* into a non-deterministic finite automaton (NFA) and understanding its accepted languages. It is noted that the language described by the expression (01+010)* includes sequences like 01010, which are not captured by the alternative expression (01)*+(010)*. The need for epsilon transitions in the NFA is questioned, with an analogy provided to clarify their importance in decision-making processes. The conversation highlights the complexity of regular expressions and their corresponding NFAs. Ultimately, the regular expression is acknowledged as a straightforward representation of the language it describes.
shivajikobardan
R=(01+010)*
For it I made the below nfa which i believe seems correct. Plus the tutorials that I am following also make sure it’s correct. Q0 is initial state(forgot to mention in figure).
https://lh6.googleusercontent.com/GUZlDA7_UjNWlcNx76e1xHOYhNjYBzbDMnP9qBnMjL8ux_Ntz3SSVIcw-VfMR6jbFlbxYG3nx6ccd2gWObG2hXnmXLE14mKI4PtFf4GtDc_PgenECvC_h_m9Yrbrg99hHZh258F9
R=(01)*+(010)*
But idk how to convert this to NFA
What will be languages accepted by this NFA? Won’t it be the same as the above one?
(for some different question)
I got small hint about this. It was to add epsilon transition, but I don’t understand the need for it.
https://lh3.googleusercontent.com/naVKgIC_8oj_v6TLAyjAhdOlLEpr4jsUAiYNw59d-2LifF5scOxn7rBw0AwCvmDwtFMZtv-s7DfXZAkt5OTNOksg7PNgzhEhyEXJ1JRmtN4nIELpWrJCIUaKA7uvrJatk6oTbd2k
Source-: https://www.cs.wcupa.edu/rkline/fcs/nfas.html
Technology news on Phys.org
I believe the regular expression offers the simplest description of this language.
The language $(01+010)^*$ contains $01010$, but $(01)^*+(010)^*$ does not.
Why do you think that this is a different question if the regular expression is the same up to replacement of 0 and 1 by $a$ and $b$?
Well, this is surprising if you understand the meaning of regular expressions. If you learned that the new gaming console would be sold at two stores only and you wanted to buy it, how can it be unclear that the first thing you need to do is to choose one of the stores and go there?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
