MHB Reid's question at Yahoo Answers regarding a first order separable IVP
The discussion addresses the initial value problem (IVP) defined by the equation y'x - 1 = 0 with the initial condition y(1) = 2. The solution process involves separating variables to derive dy = (1/x)dx. By integrating both sides with appropriate limits, the result leads to the equation y(x) - 2 = ln|x|. Ultimately, the particular solution is expressed as y(x) = ln|x| + 2. This solution satisfies the given initial condition.
MarkFL
MHB
Here is the question:
What is the particular solution to y'x-1=0 using the inition condition x=1,y=2?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello reid,
We are given the IVP:
$$y'x-1=0$$ where $$y(1)=2$$
Separating the variables, we obtain:
$$dy=\frac{1}{x}\,dx$$ where $$x\ne0$$
Switching the dummy variables of integration and utilizing the boundaries as limits, we obtain:
$$\int_2^{y(x)}\,du=\int_1^x\frac{dv}{v}$$
Applying the anti-derivative form of the FTOC, we find:
$$y(x)-2=\ln|x|$$
$$y(x)=\ln|x|+2$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
