MHB Reid's question at Yahoo Answers regarding related rates
  • Thread starter Thread starter MarkFL
    Related rates
The discussion revolves around calculating the rate at which the distance between a runner and their friend changes when the distance is 210 meters. Using the law of cosines and differentiation, a formula is derived to express this relationship. The runner moves at a constant speed of 4 m/s around a circular track with a radius of 130 m. After plugging in the values into the derived formula, the calculated rate of change in distance is approximately 3.804 m/s. Thus, the correct answer is option d), rounded to the nearest thousandth.
MarkFL
MHB
Here is the question:
How fast is the distance between the friend changing when the distance between them is 210m?
A runner sprints around a circular track of radius 130 m at a constant speed of 4 m/s. The runner's friend is standing at a distance 210 m from the center of the track. How fast is the distance between the friends changing when the distance between them is 210 m? Round the result to the nearest thousandth if necessary.
a.
3.752 m/s
b.
3.757 m/s
c.
5.014 m/s
d.
3.804 m/s
e.
3.832 m/s
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Reid,
Let's work this problem in general terms, derive a formula, and then plug in the given data.
Let $S$ be the distance of the spectator from the center of the track, $r$ be the radius of the circular track, $D$ be the distance between the runner and the spectator and $v$ be the speed of the runner.
Please refer to the following diagram:
We see, using the law of cosines, that we may state:
(1) $$D^2=r^2+S^2-2rS\cos(\theta)$$
Differentiating with respect to time, we find:
$$2D\frac{dD}{dt}=2rS\sin(\theta)\frac{d\theta}{dt}$$
$$\frac{dD}{dt}=\frac{rS}{D}\sin(\theta)\frac{d \theta}{dt}$$
Now, since the distance the runner has covered is $$d=r\theta$$ and the relationship between distance, constant velocity and time is $$d=vt$$ we may state:
$$vt=r\theta$$
Differentiating with respect to time $t$, we have:
$$v=r\frac{d\theta}{dt}$$
Hence:
$$\frac{d\theta}{dt}=\frac{v}{r}$$
And so we may state:
$$\frac{dD}{dt}=\frac{Sv}{D}\sin(\theta)$$
We also have via Pythagoras and (1):
$$\sin(\theta)=\pm\sqrt{1-\cos^2(\theta)}=\pm\frac{\sqrt{\left((r+S)^2-D^2 \right)\left(D^2-(r-S)^2 \right)}}{2rS}$$
$$\left|\frac{dD}{dt} \right|=\frac{v\sqrt{\left((r+S)^2-D^2 \right)\left(D^2-(r-S)^2 \right)}}{2Dr}$$
Plugging in the given data, we find in meters per second:
$$v=4,\,r=130,\,S=210,\,D=210$$
$$\left|\frac{dD}{dt} \right|=\frac{4\sqrt{\left((130+210)^2-210^2 \right)\left(210^2-(130-210)^2 \right)}}{2\cdot210\cdot130}=\frac{2\sqrt{1595}}{21}\approx3.803566770993497$$
Hence, the correct answer is d), rounded to the nearest thousandth.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
