Reif Ch7, Decomposition of partition function
In summary, the conversation discusses a system A consisting of two parts A' and A'' that interact weakly with each other. The states of A' and A'' are labeled as r and s respectively, and the energy of A is determined by the sum of the energies of A' and A''. The partition function Z for the total system is a sum over all states labeled by rs. The question posed is about the conversion of the sum of products to a product of sums.
msaleh87
For a system A consists of two parts A' and A'' which interact only weakly with each other, if the states of A' and A'' are labeled respectively by r and s, then a state of A can be specified by the pair of numbers r,s and its corresponding energy [itex]E_{rs}[/itex] is simply additive, i.e.,
[itex]E_{rs}[/itex] = [itex]E^{'}_{r}[/itex] + [itex]E^{''}_{s}[/itex]
The partition function Z for the total system A is a sum over all states labeled by rs, i.e.,
Z=[itex]\sum_{r,s}e^{-\beta(E^{'}_{r}+E^{''}_{s})}[/itex] = [itex]\sum_{r,s}e^{-\beta E^{'}_{r}} \ e^{E^{''}_{s}}[/itex] = ([itex]\sum_{r}e^{-\beta E^{'}_{r}}[/itex])([itex]\sum_{r}e^{-\beta E^{''}_{s}}[/itex]) = [itex]Z^{'}Z^{''}[/itex]
My question is: how the sum of product [itex]\sum ()()[/itex] is converted to product of sum ([itex]\sum[/itex])([itex]\sum[/itex]), they are not generally equal
Thanks
Do you understand why you can do this?
$$\sum_r \big[\sum_s e^{-\beta E_r}e^{-\beta E_s}\big] = \sum_r \big[ e^{-\beta E_r}\sum_s e^{-\beta E_s}\big] $$
Related to Reif Ch7, Decomposition of partition function
1. What is the partition function and why is it important in statistical mechanics?
The partition function is a mathematical concept used in statistical mechanics to calculate the thermodynamic properties of a system. It represents the sum of all possible energy states of a system, and it is important because it allows us to determine the probability of a system being in a certain state and to calculate important thermodynamic quantities such as entropy and free energy.
2. How does the partition function change when a system decomposes into smaller subsystems?
When a system decomposes into smaller subsystems, the partition function is divided into smaller partition functions for each subsystem. This is because the total energy of the system is the sum of the energies of each subsystem, and the partition function is a function of the total energy. Therefore, the partition function for the entire system is the product of the partition functions for each subsystem.
3. What is the relationship between the partition function and the Boltzmann factor?
The Boltzmann factor is a factor used to calculate the probability of a system being in a certain energy state. It is directly related to the partition function through the equation P = 1/Z * e^(-E/kT), where P is the probability, Z is the partition function, E is the energy of the state, k is the Boltzmann constant, and T is the temperature. In other words, the partition function is the sum of all Boltzmann factors for each energy state.
4. Can the decomposition of the partition function be used for any type of system?
Yes, the decomposition of the partition function can be applied to any system, as long as it can be divided into smaller subsystems. This concept is commonly used in statistical mechanics to study the thermodynamic properties of gases, liquids, and solids.
5. How does the decomposition of the partition function relate to the principle of microscopic reversibility?
The principle of microscopic reversibility states that the time-reversed process of a microscopic system should have the same probability as the original process. When the partition function is decomposed, the time-reversed process of the decomposition will also lead to the same partition function. This demonstrates the principle of microscopic reversibility and its significance in statistical mechanics.
