Related rates and flying airplane
An airplane flying horizontally at 3 miles altitude and 480 mi/hr passes directly above an observer. After 30 seconds, the plane travels 4 miles horizontally, leading to a distance calculation using the Pythagorean theorem: D = √(3² + 4²). The discussion emphasizes deriving the distance function D with respect to time, resulting in the expression D = √(3² + (4T/30)²). Differentiating this expression will yield the rate of change of distance from the observer to the airplane, which is the desired solution.
gayani
An airplane flying horizontally at an altitude of 3 miles and at a speed of 480mi/hr passes directly above an observer on the ground. How fast is the distance from the observer to the airplane increasing 30 seconds later?
can you check if this is right:
If the plane is moving at 480 mi/hr, use 30 seconds to compute how far it traveled. (480 miles/hour)(hour/60 minutes) = 8 miles/minute.
It can be seen that 30 seconds is half a minutes, so the plane would have flown half of 8 miles. You can probably do this, but 8/2=4.
If the plane were 3 miles overhead and traveled 4 miles away, the distance can be found as √(3²+4²). Compute 3². Compute 4². Add the two together. The number should be recognized as X².
rest i don't know
It's a rates problem. The vertical distance is 3mi. The horizontal distance is h(t) where h depends on time because the plane is moving. Right? They want to know what is the rate of change of sqrt((3mi)^2+h(t)^2). Take a derivative. Can you write an expression for h(t)?
hi !
yr you can derive a equation for the distance between observer and airplane
it will be like this
D=sqrt(3^2+(4T/30)^2)
hope you will know how to approach it ,here T means the time in seconds.
then just differentiate D w.r.t T
then u will get dD/dT
just subb T in the above derivative and u will get the value for the change of distance with time .i think that what u r looking for ...
it is great to help a sri lankan!reply if u want more help
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
  • · Replies 22 ·
21K
