Related Rates, formulating the problem
In summary, the problem involves a weight attached to a 50 ft long rope that passes over a pulley at point P, 20 ft above the ground. The other end of the rope is attached to a truck at a point A, 2 ft above the ground. The truck moves away at a rate of 9 ft/s and the question is asking for the rate at which the weight is rising when it is 6 ft above the ground. The solution involves using the Pythagorean theorem and solving for the horizontal distance and the height of the weight. The final answer is \frac{9}{2}\sqrt{3} ft/s.
MaxManus
277
A wight W is attached to a rope 50 ft long that passes over a pulley at point P, 20 ft above the ground. The other end of the rope is attached to a truck at a point A, 2 ft above the round. If th truck moves away at the rate of 9 ft/s, how fast is the weight rising when it is 6 ft above the ground.
I got the solution and it says:
y2 = (30 + x)2 - (18)2
and I don't understand why it is not
y2 = (30+x)2 - (20-x)2
since the rope is 50 ft long
Actually, neither of those is a "solution" to the problem stated because neither is a "rate" in ft per second. Also no equation in x and y will make sense until you say what "x" and "y" represent. I assume you mean that "y" is the height of the object above the ground but then "x" cannot the horizontal distance to the truck because you appear to be using the Pythagorean theorem but x and y do not form a right triangle.
If "x" is in fact, the horizontal distance of the truck from the point directly under the object being raised, then the rope, from the pulley to the truck, is the hypotenuse of a right triangle with one leg of length x and the other leg of length 20: that does NOT depend on the height of the lifted object. By the Pythagorean theorem, the length of that hypotenuse is [itex]\sqrt{x^2+ 400}[/itex]. If the length of the rope is 50 feet and y is the height of the lifted object, [itex]20- y+ \sqrt{x^2+ 400}= 50[/itex] so [itex]y= 20+ \sqrt{x^2+ 400}[/itex]
I am sorry, x is the distance the weight has been raised, and y is the horizontal distance from point A, where the rope is attached, to the vertical line passing through the pulley.
From the textbook solution
dy/dt = [tex]\frac{30 + x}{y}[/tex][tex]\frac{dx}{dt}[/tex]
x = 6
y = 18[tex]\sqrt{3}[/tex]
dy/dt = 9
then [tex]\frac{dx}{dt}[/tex] = [tex]\frac{9}{2}[/tex][tex]\sqrt{3}[/tex] ft/sec
Edit: Solved,
"x is the distance the weight has been raised, and y is the horizontal distance from point A, where the rope is attached, to the vertical line passing through the pulley.
FAQ: Related Rates, formulating the problem
1. What is the concept of related rates in mathematics?
Related rates is a mathematical concept that involves finding the rate of change of one variable with respect to another variable. It is used to solve problems where multiple variables are changing simultaneously and are dependent on each other.
2. How do you formulate a related rates problem?
To formulate a related rates problem, you need to identify the variables that are changing and how they are related to each other. Then, you can use the appropriate mathematical equations to express the relationship between the variables and differentiate to find the rates of change.
3. What are some common examples of related rates problems?
Some common examples of related rates problems include determining the rate at which the area of a circle is changing with respect to its radius, finding the rate at which the volume of a cone is changing as the height changes, and calculating the rate at which the distance between two moving objects is changing.
4. What are the key steps in solving a related rates problem?
The key steps in solving a related rates problem are identifying the variables and their relationships, setting up an equation that relates the variables, differentiating both sides of the equation with respect to time, plugging in the given values and solving for the unknown rate of change.
5. How do you know if you have correctly solved a related rates problem?
You can check if you have correctly solved a related rates problem by verifying that your answer makes sense in the context of the problem and by checking if it satisfies the given conditions and constraints. It is also helpful to double-check your calculations and ensure that all units are consistent.
12K
