Relating molecules, atoms to number of optical branches (modes)
In summary, the number of optic branches (modes) present in a unit cell with X molecules and Y atoms per molecule can be calculated by considering the degrees of freedom of each individual atom and molecule. In a single unit cell, there are 3 acoustic branches and 3*atoms-3 optic branches. If we group the atoms into molecules, there will be 3*molecules for the degrees of freedom of each molecule and 3*atoms for the degrees of freedom of each atom. This results in a total of 3*X*Y-3*X optic branches. Additionally, there will be intermediate frequency branches corresponding to molecules moving out of phase, and relatively flat optical bands that correspond to the vibrational modes of the free molecules.
war485
92
I'm stumped as to how many optic branches (modes) are present if there are X number of molecules in a unit cell and Y number of atoms in each molecule.
I know that each individual atom has 3 degrees of freedom and more generally in a single unit cell, there are 3 acoustic branches (modes) and 3*atoms-3 number of optic branches (modes). There should be a total of 3*atoms branches (modes) due to the degrees of freedom. I'm struggling to understand how to generalize this further to include molecules into the picture.
Logically speaking, 3*molecules for all the degrees of freedom in a molecule, and 3*atoms for all the degrees of freedom of an atom. Maybe each molecule can be thought of as an individual unit cell inside a larger unit cell. Would there be a total number of 3*X*Y-3*X optical branches (modes)?
The total number of branches has to be the same, if you group your atoms into molecules or not.
Let's assume that the interactions within the molecule(s) are stronger than the interactions between molecules. Like for example in a crystal of bucky balls.
The 3 acoustic branches will correspond to the long-wavelength displacement of entire molecules.
Then there should be branches of intermediate frequency corresponding to molecules moving out of phase, similar to optical modes when you put a simple atom in the place of the molecule. If there are X molecules in the unit cell, then you should get 3X-3 bands like this.
Finally, there should be relatively flat optical bands that correspond more or less to the vibrational modes of the free molecules.
If there are Y atoms in the molecule, then each molecule has 3Y-3 modes, giving X(3Y-3) modes total that will be very close to each other (because vibrations of one molecule will likely have very little effect on the vibrations of the other molecules).
That makes a total of 3+3X-3 + 3X(Y-1) = 3XY bands, which is exactly 3 times the number of atoms - as it should be.
Related to Relating molecules, atoms to number of optical branches (modes)
1. How do molecules and atoms relate to the number of optical branches (modes)?
Molecules and atoms have different numbers of atoms and bonds, which affect the number of optical branches or modes. The more atoms and bonds a molecule or atom has, the more complex its structure and the higher the number of optical branches or modes.
2. What are optical branches or modes?
Optical branches or modes refer to the different ways a molecule or atom can vibrate or rotate. These vibrations and rotations are caused by the movement of atoms and bonds within the molecule or atom.
3. How are the number of optical branches (modes) determined?
The number of optical branches or modes is determined by the number of atoms and bonds in a molecule or atom. Each atom can contribute to the number of modes, and the type of bond (single, double, triple) also affects the number of modes.
4. How do optical branches (modes) affect the properties of a molecule?
The number of optical branches or modes can affect the properties of a molecule, such as its stability, reactivity, and energy levels. The different modes can also influence how the molecule interacts with other molecules and its overall behavior.
5. Can the number of optical branches (modes) be changed?
The number of optical branches or modes is determined by the structure and composition of a molecule or atom, so it cannot be changed without altering the molecule or atom itself. However, the intensity and frequency of the modes can be altered by changing the temperature or pressure of the system.
  • Atomic and Condensed Matter
