LemoneyF
- 3
Hi Guys
This is school physics problem, but it doesn't really fit the criteria of a homework post as its not a set question and I am not after an answer, just an idea of where to go next. The task was completely up to us, so I had to go and unknowingly pick the one that would brutally mindf**k me. I know its something so simple, something obvious I am not seeing. I could be way off, who knows.
The aim of the investigation is to relate the sink time of saxon bowls in water, (supposedly used back in their time to give a person a set time to speak in their meetings and what not) to the diametre of the holes drilled in the bottom of them. From what I understand the theory behind it will largely be based upon Bernoulli's Equation,
P1 + 1/2pv1^2 + pgh1 = P2 + 1/2pv2^2 + pgh2
So taking equally sized PVC pipe end caps with differing sized holes drilled in their centres; times taken for them to competely submerge beneath the surface of water were taken. Temperature and density were kept constant.
Holes ranging from 6-16mm were drilled, with all 'bowls' having volumes of 61ml. The sink times followed a roughly exponential pattern when averages were taken and they were graphed.
Flow rate Q= A/V
So I've modeled this so far by looking at the velocity of the water entering the hole (and subsequently the fill rate), caused by the pressures of water acting on the bowl (bouyant force); and the velocity of the bowl moving downwards in relation to the water, caused by the combined forces of air pressure and weight. I have half a notebook full of scribbled notes but haven't really gotten much further than the basic concept. And I know this is post is probably missing information still. Can anyone help? :s
