Relating variables: weight, gear ratio, power/torque to make design estimations
In summary, the conversation involved someone seeking advice on how to model the relationship between weight, gear ratios, power, torque, and acceleration in the early stages of designing a vehicle. They were looking for rough correlations and someone suggested using an acceleration simulator that takes into account power, weight, and tire friction coefficient. The simulator can be more precise if other vehicle characteristics are known and the theory behind it is explained on the website.
brent s
hey all, I'm stumped so I thought I'd try posting here.
I am in the early stages of design of a vehicle where we have a rough approximation of weight, no idea what gear ratios or power/torque to use yet, but have an acceleration requirement. I am trying to graphically model the relationship between some of these parameters to help get some design drivers. Any idea how I could proceed? Thanks!
I should mention, nothing needs to even be close to exact, I just want some rough correlations plotted to compare different design alternatives. Thanks again!
You can used this acceleration simulator. It gives you the acceleration potential of a vehicle based on power, weight and tire friction coefficient. It can be more precise if you know other vehicle characteristics like aerodynamics, weight distribution, etc. The theory behind it is explained on the website.
Oh man. That's everything I wanted and then some.
I would recommend starting by defining the specific goals and requirements for the vehicle design. This will help determine which variables are most important to consider and how they should be related to each other.
Next, I would suggest conducting research on similar vehicle designs and their performance characteristics. This can provide a baseline for understanding the relationship between weight, gear ratio, and power/torque.
From there, you could create mathematical models or use simulation software to explore different combinations of these variables and their effects on acceleration. This can help identify potential design drivers and inform your decision-making process.
It may also be helpful to consult with experts in the field, such as engineers or automotive specialists, for their insights and expertise on this topic.
Overall, it is important to approach this task with a systematic and analytical mindset, gathering as much information as possible to make informed design estimations. Good luck with your project!
Related to Relating variables: weight, gear ratio, power/torque to make design estimations
1. How does weight affect the performance of a design?
Weight can greatly impact the performance of a design. Generally, the heavier the design, the more power and torque will be required to move it. This can also impact the gear ratio needed to achieve the desired performance. A lighter design can often be more efficient and require less power to achieve the same results.
2. What is the relationship between gear ratio and power/torque?
The gear ratio is the relationship between the number of teeth on two gears that are meshed together. A higher gear ratio will result in more power and torque being transferred to the output, while a lower gear ratio will result in less power and torque being transferred. It is important to consider the desired power and torque when selecting a gear ratio for a design.
3. How can power/torque be estimated for a design?
Power and torque can be estimated by using equations such as P = T x N and T = F x r, where P is power, T is torque, N is rotational speed, F is force, and r is the radius of the gear. These equations can be used to estimate the power and torque needed to achieve a certain performance for a design.
4. What factors should be considered when selecting a gear ratio for a design?
Several factors should be considered when selecting a gear ratio for a design, including the desired performance, weight of the design, available power and torque, and the type of gear system being used. It is important to carefully analyze these factors to determine the most suitable gear ratio for the design.
5. How can weight be estimated for a design?
Weight can be estimated by calculating the weight of individual components and then adding them together. It is also important to consider the weight of any additional components that may be added during the design process. Using estimations and calculations, an accurate weight for the design can be determined.
