Relation between affine connection and covariant derivative
In summary: In the einstein field equitations the ricci curvature tensor is used, the non trivial contraction of the riemann curvature tensor.This is actually a bit of a technicality. The Ricci curvature tensor on a manifold is not just the sum of the Ricci curvature tensors of the individual curves in the manifold. It's a tensor that takes into account the curvature of the manifold as a whole, not just the individual curves.
nilsgeiger
I now study general relativity and have a few questions regarding the mathematical formulation:
1) What ist the relation between an connection and a covariant derivative?
Can you explain the exact difference?
2) One a lorentzian manifold, what ist the relation between the levi-civita-connection and the used covariant derivative?
Unrelated, but probably not important enough to justify a new thread:
3) In the einstein field equitations the ricci curvature tensor is used, the non trivial contraction of the riemann curvature tensor.
My professor told me, you can understand this as averaging along all curves of the parellel transports.
Is there an easy way to see this?
The affine connection is the operator ##\nabla## that takes a vector and a vector field as input and gives a vector as result. A covariant derivative is the result ##\nabla_XY## of applying that operator to a vector field ##Y## and a vector ##X##.
At least, that's the definition used in my text: John Lee's 'Riemannian Manifolds: an Introduction to Curvature'. I daresay the exact definitions vary between writers.
If one follows the framework of my previous post, the Levi-Civita connection on a Pseudo-Riemannian manifold is the affine connection that is both symmetric and compatible with the metric. 'Compatible' has a number of different definitions, the simplest of which is that the metric must have zero covariant derivative under that connection, in every direction, everywhere in the manifold (often written as ##\nabla g\equiv 0##).
It is provable that the Levi-Civita connection is unique, ie there is only one affine connection on a Pseudo Riemannian manifold that has those two properties.
The covariant derivative of a vector field on a Pseudo-R manifold with respect to a vector in its tangent bundle will be the result of applying the Levi-Civita connection to that vector field and vector.
Related to Relation between affine connection and covariant derivative
1. What is the difference between an affine connection and a covariant derivative?
The main difference is that an affine connection is a geometric object that describes the parallel transport of vectors along a curved space, while a covariant derivative is a mathematical operation that involves differentiating a vector or tensor field along a manifold.
2. How are affine connections and covariant derivatives related?
An affine connection is used to define the covariant derivative. The covariant derivative of a vector field is defined in terms of the affine connection and the directional derivative of the vector field in a given direction.
3. Can an affine connection exist without a covariant derivative?
Yes, an affine connection can exist without a covariant derivative. An affine connection can be seen as a more general concept, as it is a geometric object that can be defined on any manifold, while a covariant derivative is a specific mathematical operation that requires an affine connection to be defined.
4. How does an affine connection affect the curvature of a manifold?
An affine connection is used to define the curvature of a manifold. It determines how vectors are transported along different paths on the manifold, and this affects the overall curvature of the manifold. A non-flat affine connection will result in a curved manifold.
5. Are there any real-life applications of the relation between affine connection and covariant derivative?
Yes, the relation between affine connection and covariant derivative is essential in the field of general relativity. It is used to describe the curvature of spacetime and the motion of particles in a gravitational field. It is also used in other areas of physics, such as fluid mechanics and electromagnetism.
