Relation between angular and linear velocity
In summary, v refers to the tangential linear speed in this context. For an object in circular motion, there is no radial linear velocity. The angular speed ω represents the angular rotation frequency, and the equation v=rω can be derived from the relationship between circular arc length and angle. There is no radial velocity because there is no radial displacement.
anigeo
84
v=rω.here , what does v(linear velocity) refer to?tangential velocity or radial velocity.further which velocity is responsible for centripetal acceleration?
In this case, v is the tangential linear speed. If you were to cut the string that pulls a ball into a circular path, the string would fly off in a straight line at speed v in the direction tangent to the point on the circle where it was when the string is cut (neglecting relativistic effects). For an object in constant circular motion, there is no linear radial velocity. If an object is spiraling in (for instance, you are shortening the string) then it has both a tangential linear velocity and a radial linear velocity.
The angular speed ω is essentially the angular rotation frequency, i.e. the number of times it goes around in a circle per unit time. You can derive and understand the equation you wrote by first convincing yourself using geometry that the length of a circular arc s is just the angle θ it subtends times its radius r:
s = rθ
If you assume constant r and differentiate both sides with respect to time, you end up with your equation relating linear and angular speeds.
Thanks c. Baird . i just got it that there can be no radial velocity as there is no radial displacement.
FAQ: Relation between angular and linear velocity
What is the difference between angular velocity and linear velocity?
Angular velocity is the rate at which an object rotates around a fixed point, while linear velocity is the rate at which an object moves in a straight line. Angular velocity is measured in radians per second, while linear velocity is measured in meters per second.
How are angular and linear velocity related?
Angular and linear velocity are related through the formula v = rω, where v is linear velocity, r is the distance from the object to the point of rotation, and ω is the angular velocity. This means that the linear velocity of an object is directly proportional to its angular velocity and the distance from the point of rotation.
Can angular and linear velocity be different for the same object?
Yes, it is possible for an object to have different angular and linear velocities. This can occur when the object is moving along a curved path, as the linear velocity will change depending on the point of the curve, while the angular velocity remains constant.
How does increasing the angular velocity affect the linear velocity?
Increasing the angular velocity will also increase the linear velocity, as long as the distance from the point of rotation remains constant. This means that the object will move faster in a straight line as it rotates faster around the fixed point.
What is the unit of measurement for angular and linear velocity?
Angular velocity is typically measured in radians per second (rad/s), while linear velocity is measured in meters per second (m/s). However, other units of measurement such as revolutions per minute (rpm) and kilometers per hour (km/h) can also be used for both angular and linear velocity.
