Relation between inequalities for first and second derivatives
In summary, the conversation discusses the relationship between the first and second derivatives of a function, and whether the inequality f'(x) >= f'(y) implies f''(x) >= f''(y). The conclusion is that this inference cannot be generally drawn and is only true under certain bounds, as the two derivatives can vary and become greater or smaller for different functions. The concept of Taylor series is also mentioned as a way to represent a function and visualize the relationship between the first and second derivatives. A counterexample is provided to demonstrate that two functions with the same first derivative do not necessarily have the same second derivative.
nikozm
54
Hi,
If f'(x) >= f'(y) can we say that f''(x) >= f''(y) also holds ? And if yes under which conditions ?
Thanks
No, no such inference can be generally drawn.
A simple counter example is
F(x)= x ^2
G(x)= 1,000,000,000,000,000,000 x
DF = 2x
DG= 1,000,000,000,000,000,000
D^2F = 2
D^2G= 0
For x > 500,000,000,000,000,000
nikozm said:
Hi,
Thanks
is not correct. For anything below those bounds it is right. The inequality you stated is only true under certain bounds because the two derivatives vary and may periodically become greater or smaller as in the sine and cosine functions. Bounds the inequality is true under need to be specified , to answer questions about the examples of the inequality you stated. Also because the derivative is a function it varies inequalities can't though and become false for certain values of the function. (The sine cosine remark serves as a good example, but I'm leaning towards arbitrary functions varying in all different manners not just varying periodically.)
do you know about taylor series? In that series representation of a function, the first derivative is the linear coefficient and the second derive active is (twice) the quadratic coefficient. Your question is thus sort of like asking whether two taylor writes which have the same linear coefficient must also have the same quadratic coefficient. Of course not, as the second coefficient can be anything.
Or geometrically, the first derivative measures the slope of the graph while the second derivative measures the convexity. so this is like asking whether two graphs with the same slope must also have the same convexity, or concavity at a point. can you draw a counterexample?
FAQ: Relation between inequalities for first and second derivatives
What is the relation between inequalities for first and second derivatives?
The relation between inequalities for first and second derivatives is known as the second derivative test. It is used to determine the concavity and convexity of a function and whether a critical point is a maximum or minimum point.
How is the second derivative test used to find maximum and minimum points?
The second derivative test involves taking the second derivative of a function and evaluating it at a critical point. If the second derivative is positive, the critical point is a minimum point. If the second derivative is negative, the critical point is a maximum point.
Can the first derivative test be used to determine maximum and minimum points?
No, the first derivative test can only determine whether a critical point is a local maximum or minimum point. It cannot determine the nature of the critical point (maximum or minimum) like the second derivative test can.
What is the relationship between the sign of the first derivative and the concavity/convexity of a function?
If the first derivative is positive, the function is increasing and the concavity is upward (convex). If the first derivative is negative, the function is decreasing and the concavity is downward (concave).
Can the second derivative test be used to find inflection points?
Yes, the second derivative test can also be used to identify inflection points. If the second derivative changes sign at a critical point, then that critical point is an inflection point.
