MHB Relation between matrix elements of momentum and position operators
The discussion revolves around finding the relationship between the matrix elements of the momentum operator (p) and the position operator (x) in the context of a Hamiltonian for a single particle. The key equation derived is $$\frac{ \langle i \, | \, p \, | j \rangle}{\langle i \, | \, x \, | j \rangle} = \frac{iM(E_i - E_j)}{\hbar},$$ which connects the eigenvalues of the Hamiltonian to the matrix elements of the operators. The calculations involve using canonical commutation relations and the commutator of x with the Hamiltonian to derive necessary expressions. The approach highlights the importance of understanding how to compute matrix elements and the role of energy eigenvalues in these calculations. Overall, the discussion emphasizes the mathematical relationships that can be established through operator algebra in quantum mechanics.
Fantini
MHB
Hello. I'm having trouble understanding what is required in the following problem:
Find the relation between the matrix elements of the operators $\widehat{p}$ and $\widehat{x}$ in the base of eigenvectors of the Hamiltonian for one particle, that is, $$\widehat{H} = \frac{1}{2M} \widehat{p}^2 + V(\widehat{x}).$$
I don't understand what kind of relation he is asking for. The eigenvectors for the Hamiltonian satisfy the equation $\widehat{H} \varphi_i = E_i \varphi_i$, but I don't know how to use that. The answer is $$\frac{ \langle i \, | \, p \, | j \rangle}{\langle i \, | \, x \, | j \rangle} = \frac{iM(E_i - E_j)}{\hbar},$$ but it doesn't enlighten me.
How do I find an arbitrary matrix element of an operator?
Mathematics news on Phys.org
Just thinking out loud here. First off, we can tidy up the notation so that everything matches: $\hat{H} \, |i\rangle =E_i \, |i\rangle$, and the same for $j$. Let's remember some of the canonical commutation relations, in case they prove useful:
\begin{align*}
[x,p]&=i\hbar \\
[x,x]&=0 \\
[p,p]&=0 \\
[AB,C]&=A[B,C]+[A,C]B.
\end{align*}
The last allows us to compute
\begin{align*}
[x,H]&=\left[x,\frac{p^2}{2M}+V(x)\right] \\
&=\frac{1}{2M} \, [x,p^2]+\underbrace{[x,V(x)]}_{=0} \\
&=-\frac{1}{2M} \, [p^2,x] \\
&=-\frac{1}{2M} \, \left( p[p,x]+[p,x]p \right) \\
&=\frac{i \hbar}{M} \, p.
\end{align*}
The reason I computed this commutator is because the answer has $E_i$ and $E_j$ in it, leading me to think that we're going to have to calculate something with an $H$ in it. If you calculate $[x,H] \, |j\rangle$ two different ways, you get
$$[x,H] \, |j\rangle = \frac{i\hbar}{M} \, p \, |j\rangle = (E_j-H) \, x \, |j\rangle.$$
Here, I have done
\begin{align*}
[x,H] \, |j\rangle&=(xH-Hx) \, |j\rangle \\
&=xH \, |j\rangle - Hx \, |j\rangle \\
&=x E_j \, |j\rangle-Hx \, |j\rangle \\
&=E_j \, x \, |j\rangle -Hx \, |j\rangle \\
&=(E_j-H) \, x \, |j\rangle.
\end{align*}
It seems to me that these computations might help. Does this give you any ideas?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
