Relation between mole, volume and pressure fraction
In summary, all three components are in a single vessel of volume and the pressure and volume fractions are the same.
subhradeep mahata
120
If mole fraction, pressure fraction and volume fraction are denoted by Xmol , Xp, XV respectively, of a gaseous component, then what is the relation between them?
mole fraction = mole of component / total moles
pressure fraction = pressure of component / total pressure
volume fraction = volume of component / total volume
Well, to be honest, I simply don't know where to start from. But still, have a look at my method (even if it is stupid) :
Let's assume there are 3 gaseous components.
mole fraction of 1st component (at const. temp.) = n1 / n1+n2+n3
= P1V1 /( P1V1+P2V2+P3V3) (cancelling the RT terms, T being constant) (equation 1)
=P1 / (P1+P2+P3) ...pressure fraction assuming constant volume (from eq.1)
=V1 / (V1+V2+V3) ...volume fraction assuming constant pressure (from eq. 1 )
So, my answer is that all three are same, which happens to be the correct answer according to my book. But i still need some clarifications, is it justified to assume volume to be constant for calculating pressure fraction? please help me out. If you find my answer to be incorrect, please give me the correct proof.
I think that the relation "pressure fraction = pressure of component / total pressure" assumes that all three components are contained in a single vessel of volume ##v##. So you have ##X_{p}=\frac{p1\:v}{p1\:v+p2\: v+p3\:v}##
There is some inconsistency in the way people talk about gas mixtures. Sometimes each gas is assumed to occupy the total volume, with partial pressures P1, P2 and P3, and total pressure P = P1 + P2 + P3. Sometimes they are thought of as all being at a constant pressure P, and occupying fractions of the total volume equal to their mole fractions (assuming ideality). The first is more physically realistic - the concept of volume fraction is not so meaningful as it is in a liquid mixture, where each component excludes the others from the volume it occupies, whereas in the gas the molecules are zooming round in empty space and not excluding each other from their "fraction" of the volume. Nevertheless, the second approach is sometimes useful to work with, particularly in the case of chemical reactions that produce or consume gas. For example, suppose you have a solid under an atmosphere of air of volume V at a given pressure P. If the solid decomposes producing a gas, and at constant pressure the total gas volume increases by ΔV, you can say that "a volume ΔV of gas at pressure P was produced by the reaction" and calculate the number of moles. In reality of course the gas will mix with the air and not occupy a separate volume ΔV - but not instantaneously.
Likes subhradeep mahata
When people talk about volume fraction, what they really mean is mole fraction. This has never made sense to me either, but that's the way it's done.
Of course, by Dalton's law, pressure fraction and mole fraction are the same.
Likes Bystander
@Chestermiller
We know, partial pressure=mole fraction *total pressure
or, partial pressure/ total pressure = mole fraction
or, pressure fraction = mole fraction
Is it correct?
And is it correct to use mole fraction and volume fraction interchangeably ?
FAQ: Relation between mole, volume and pressure fraction
What is a mole?
A mole is a unit of measurement used in chemistry to represent the amount of a substance. It is defined as the amount of a substance that contains the same number of particles as there are atoms in 12 grams of carbon-12.
How are moles, volume, and pressure fraction related?
In a given volume of gas, the number of moles and the pressure fraction are directly proportional. This means that as the number of moles increases, the pressure fraction also increases, and vice versa.
How does volume affect the number of moles and pressure fraction?
As the volume of a gas increases, the number of moles decreases, while the pressure fraction remains constant. This is known as Boyle's Law, which states that at a constant temperature, the volume of a gas is inversely proportional to the number of moles.
How does pressure affect the number of moles and pressure fraction?
As the pressure of a gas increases, the number of moles and the pressure fraction also increase. This is known as Gay-Lussac's Law, which states that at a constant volume, the pressure of a gas is directly proportional to the number of moles.
What is the ideal gas law and how is it related to moles, volume, and pressure fraction?
The ideal gas law is a mathematical equation that describes the relationship between the pressure, volume, temperature, and number of moles of an ideal gas. It is expressed as PV = nRT, where P is the pressure, V is the volume, n is the number of moles, R is the gas constant, and T is the temperature. This equation shows that the number of moles, volume, and pressure fraction are all interconnected and can be used to predict the behavior of gases under different conditions.
