Emspak
- 243
- 1
Estimate the magnitude of the fine structure splitting in H-α in THz
Rydberg -- [itex] R_y \left(\frac{1}{n_f^2}-\frac{1}{n_i^2}\right) = \Delta E[/itex]
This isn't really a request for solution help, and more a justification. I know that if I apply the above equation I get (-13.6eV) (5/36)~ 1.9 eV and from there I get a wavelength (~656 nm). So far so good. I also know that the fine structure constant α2 multiplied by that will give me a change in frequency. That is the splution sheet says "~α2 (1.9eV) " and proceeds to say that if you multiply the reciprocal of that by 242 THz you get 6.8 GHz.
Well an good, but I am trying to justify this better. I know that 656nm ~ 1.9 GHz. I just want to figure out how to make the step. That is, it seems right, but if someone said "Hey this is the equation they are using" that would help.
I also ask this because it seemed to me that if one could derive the magnetic field experienced by an electron as it runs around the nucleus one could get the same result. Bu my attempts to do so so far have met with little success-- I feel like I am perhaps overcomplicating things. (I tried starting with the old equation for B field in a current loop and going from there, using the Bohr radius, but I ended up with stuff that stopped making sense).
Anyhow, to recap: first, justify the answer, second, is there a link to a derivation or something that I am missing.
THanks folks.
