Relation on X: Symmetry, Reflexivity & Transitivity
  • Thread starter sam0617
  • Tags
    Symmetry
In summary: So it is not transitive.In summary, the relation R in question 1 is symmetric but not reflexive or transitive because it does not hold for all x,y,z, but only for some. In question 2, R is symmetric and transitive, but not reflexive because it holds for all x,y,z, but not for (a,a).
sam0617
Let X = { a, b, c }
X x X = { (a,a), (b,b), (c,c) }
{ (a,b), (b,a), (a,c), (c,a) }
{ (b,c), (c,b) }
1. Symmetric but not reflexive or transitive:
R = { (a,b), (b,a), (a,a), (b,c), (c,b) }
How come this is right? Isn't aRb, bRa imply aRa? isn't that transitive? is it because (b,c,), (c,b) is there but not (b,b) the reason why R is not transitive?
I ask because the 2nd question is confusing. Here it is:
2. Symmetric and transitive but not reflexive:
R= { (a,a), (a,b), (b,a), (b,b) }
See how aRb, bRa implies aRa so therefore it's transitive? How come it doesn't hold for the 1st question??
Thank you for any help.
Transitive means that for ALL x,y,z:
[tex]xRy~\text{and}~yRz~\Rightarrow~xRz[/tex]
It must holds for ALL.
For the first one, it isn't transitive since if you take x=z=a and y=x, then you see that the above is not satisfied. So it doesn't hold for ALL x,y,z. It does hold for some x,y,z. But it does hold for some. But some isn't enough to imply transitivity.
In (2), it does hold for ALL, so it is transitive.
I'm sorry, I don't understand what the x=z=a and y=x then it wouldn't satisfy above.
Could you explain more?
EDIT: Then to make question 1 transitive, all I would have to add is (b,b) ?
Sorry, typo. I meant that if x=z=b and y=c, then it isn't true that bRc and cRb and bRb.
Adding (b,b) would not make it transtive.
Indeed, we also don't have
aRb and bRc => aRc
since (a,c) is not in the relation.
I can explain the concepts of symmetry, reflexivity, and transitivity in relation to the given content on X.
Symmetry refers to a relation where if (a,b) is in the relation, then (b,a) is also in the relation. This means that the order of the elements does not matter. In the given example, both R in the first and second question are symmetric because for every pair (a,b) in R, the pair (b,a) is also present.
Reflexivity refers to a relation where every element is related to itself. In the first question, R is not reflexive because (a,a) and (b,b) are not present in R. However, in the second question, R is reflexive because (a,a) and (b,b) are present in R.
Transitivity refers to a relation where if (a,b) and (b,c) are in the relation, then (a,c) is also in the relation. This means that if there is a chain of related elements, then the first and last elements are also related. In the first question, R is not transitive because although (a,b) and (b,c) are present, (a,c) is not. This is because (b,c) and (c,b) are present, but (b,b) is not, which breaks the transitive property. In the second question, R is transitive because for any elements a, b, and c, if (a,b) and (b,c) are present, then (a,c) is also present.
In summary, the first question is an example of a symmetric relation that is not reflexive or transitive, while the second question is an example of a symmetric and transitive relation that is also reflexive. The difference lies in the specific pairs of elements that are included in the relation.
FAQ: Relation on X: Symmetry, Reflexivity & Transitivity
What is meant by symmetry in a relation?
Symmetry in a relation on X means that for any two elements x and y in X, if (x,y) is in the relation, then (y,x) must also be in the relation.
What is reflexivity in a relation on X?
Reflexivity in a relation on X means that every element of X is related to itself. In other words, for any element x in X, (x,x) is in the relation.
What does it mean for a relation on X to be transitive?
A relation on X is transitive if, for any three elements x, y, and z in X, if (x,y) and (y,z) are both in the relation, then (x,z) must also be in the relation.
How do I determine if a relation on X is symmetric?
To determine if a relation on X is symmetric, you can check if for every pair of elements x and y in X, if (x,y) is in the relation, then (y,x) must also be in the relation. If this holds true, the relation is symmetric.
What are examples of symmetric, reflexive, and transitive relations?
Examples of symmetric relations include the "equal to" relation (for example, 2=2 is true if and only if 2=2 is true), and the "parallel to" relation (for example, if line A is parallel to line B, then line B is parallel to line A). Examples of reflexive relations include the "less than or equal to" relation (for example, 3≤3 is always true), and the "is a subset of" relation (for example, the set {1,2} is a subset of {1,2,3}). Examples of transitive relations include the "less than" relation (for example, if a < b and b < c, then a < c), and the "ancestor of" relation (for example, if person A is an ancestor of person B and person B is an ancestor of person C, then person A is an ancestor of person C).
