MHB Relation within Gauss-Newton method for minimization
The Gauss-Newton method updates the parameter θ in nonlinear regression by minimizing the sum of squares of residuals. The update formula is derived from the first-order Taylor expansion of the function around the current estimate. Specifically, the update is expressed as θ^(t+1) = θ^(t) + [(A^(t))^TA^(t)]^(-1)(A^(t))^Tx^(t), where A^(t) contains the Jacobian of the model and x^(t) represents the residuals. This formulation allows for efficient computation of the parameter updates by leveraging matrix operations. Understanding these relationships is crucial for implementing the Gauss-Newton method effectively in optimization tasks.
i_a_n
If we study model fit on a nonlinear regression model $Y_i=f(z_i,\theta)+\epsilon_i$, $i=1,...,n$, and in the Gauss-Newton method, the update on the parameter $\theta$ from step $t$ to $t+1$ is to minimize the sum of squares $\sum_{i=1}^{n}[Y_i-f(z_i,\theta^{(t)})-(\theta-\theta^{(t)})^Tf'(z_i,\theta^{(t)})]^2$. Can we prove that (why) (part 1) the update is given in the following form: $\theta^{(t+1)}=\theta^{(t)}+[(A^{(t)})^TA^{(t)}]^{-1}(A^{(t)})^Tx^{(t)}$,(part 2) where $A^{(t)}$ is a matrix whose $i$-th row is $f'(z_i,\theta^{(t)})^T$, and $x^{(t)}$ is a column vector whose $i$-th entry is $Y_i-f(z_i,\theta^{(t)})$.
Any solution or hints? How to derive those relationships?
Thanks in advance!
Thanks in advance!
How are those iterations (or updates) defined in the Gauss-Newton method?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
