- #106
PeterDonis
Mentor
- 47,604
- 23,877
Excuse me? You said:AndreiB said:This is not about accurate position measurements
So yes, what you're claiming is about accurate position measurements.AndreiB said:Currently, QM does not impose any limit for the accuracy of a position measurement.
So is your claim that we can make accurate measurements at sub-Planckian scales. I am perfectly fine with eliminating both claims from this discussion and confining ourselves to scales at which we have some prospect of doing actual experimental tests. But you are the one who brought in sub-Planckian scales, not me.AndreiB said:I think this is pure speculation.
No, I said that it's not actually necessary for the "detector" to have any output that humans can read. But it is necessary for a "detector" to be there--to have something at each slit that can in principle provide which-path information. That requires not just "interaction", but a precisely chosen interaction that can provide that information. A rock does not qualify; if it did, we would be using rocks instead of highly expensive detectors to run double-slit experiments--you could just put a rock at each slit and watch the interference pattern disappear. But of course nobody does that, because physicists, unlike you, know that it would be foolish.AndreiB said:You already agreed that, in the case of the of a 2-slit experiment it's not actually necessary to detect the photons that carry the relevant which-path information.
