Relationship between constructibility of reg. polygons and cot(pi/N)
In summary, the conversation touched upon the relationship between the constructibility of regular polygons and the reducibility of trigonometric functions into expressions of square roots. The speaker discovered a general pattern for finding the area of an N-gon, and noticed that the function cot(pi/N) was reducible if and only if the polygon was constructible. They also posed four challenging questions for further exploration and discussion.
ellipsis
158
24
Full title: Relationship between the constructibility of regular polygons and the reducability of trigonometric functions into expressions of square roots.
I stumbled upon this after I derived the formula for the area of a triangle given it's side length x as a trigonometry exercise. ## A = \frac{1}{2}\sin{(60°)}x^2 = \frac{\sqrt{3}}{4}x^2 ##. I challenged myself to find the area formulas for every N-gon until I found a pattern. I did square, pentagon, and hexagon using basic trigonometry, and reducing the trigonometric functions into square root expressions using Wolfram.
Things started to get weird when I got to heptagon or the 7-gon, though. Wolfram wouldn't reduce it, and my area equation was made ugly by the presence of a trig function. (I spent a good few hours researching how to find exact trig values by hand using the half-angle formula et al, before I realized it was impossible)
Then I tried to find a general angle formula, but I couldn't write the later trigonometric functions in terms of sine. Eventually I figured out cot() is the only one that works (but I don't know why). This general pattern popped out at me:
$$ A = \frac{N}{4}\cot{\frac{\pi}{N}} $$
After I got to the 11-gon I started noticing another pattern: Whether or not the function ##\cot(\frac{\pi}{N})##, where N is the number of sides, is reducible has the same truth value as whether or not a given polygon is constructible. (I was amazed by this). Also, the relative complexity of each square-root expression is correlated with the relative complexity of the construction of that polygon. (As first seen with the long and convoluted 17-gon)
The wiki page for the 17-gon mentions that its area and constructibility was determined by Gauss 200 years ago, while he was going through this thought process, sqeeee!). It also claimed he had a method of determining whether cot(pi/N) was in general reducible, based on some property of "fermat" primes.
________________________________________________________________________________
I had two other non-trivial observations:
1. The square root expression of cot(pi/N) has a similarity with cot(pi/(2N)). Something to do with the half angle formula, maybe.
2. If cot(pi/N) cannot be reduced, then cot(pi/(2N)) cannot be reduced either.
I also found the entry in the OEIS of the integer sequence of non-constructible polygons:
http://oeis.org/A004169
It mentions a generating function, but I don't know what the "totient function, phi" is yet.
I can research what the totient function is on my own, but...
I have four challenging questions that I think this board will be interested in:
1. Does there exist a general algorithm for determining the exact value of ##\cot(\frac{\pi}{N})## in terms of square roots if such an expression exists?
2. Likewise, is there a general algorithm to derive the steps of constructing a regular polygon with a number of sides ##N##?
3. Does there exist a linear-time algorithm for converting a square-root expression into a set of polygon construction steps?
Beyond a certain degree of self-interference and complexity, a system can be used as an analogue to a Turing machine (i.e. it can be used for arbitrary computation). If a system is beyond that point, it makes certain statements about that system undecidable, such as if it will enter into an infinite-regress or not.
4. If you had infinite time, infinite paper, and an unmarked ruler and compass - could you do the same set of problems as a Turing machine?
_________________________________________________________________________________
Here's my observations on the possible answers:
* I suspect questions 1 and 2 have the same truth value.
* I suspect question 3 is true (there is a linear time algorithm for converting between a square-root expression and a set of instruction for polygon construction)
* I suspect question 4 is the negation of questions 1 and 2.
NOTE: I won't be disappointed with answers like "One could write a whole original book on this topic, nobody knows yet." I just want to encourage discussion on an interesting problem. I'm about to leave for class, so I won't be back for a while.
Mathematics news on Phys.org
bump
/10word
Related to Relationship between constructibility of reg. polygons and cot(pi/N)
What is the relationship between the constructibility of regular polygons and cot(pi/N)?
The relationship between the constructibility of regular polygons and cot(pi/N) is that a regular polygon with an odd number of sides (N) is constructible if and only if cot(pi/N) is a rational number. This means that the regular polygon can be constructed using a compass and straightedge.
How does cot(pi/N) affect the constructibility of regular polygons?
Cot(pi/N) is a measure of the slope of a line that intersects the unit circle at an angle of pi/N. The constructibility of regular polygons is dependent on the value of cot(pi/N) being a rational number. If cot(pi/N) is irrational, then the regular polygon is not constructible.
What is the significance of cot(pi/N) in the constructibility of regular polygons?
Cot(pi/N) is significant because it determines whether a regular polygon can be constructed using a compass and straightedge. If cot(pi/N) is rational, then the regular polygon is constructible. If it is irrational, then the regular polygon is not constructible.
Can a regular polygon with an even number of sides be constructed using a compass and straightedge?
No, a regular polygon with an even number of sides cannot be constructed using a compass and straightedge. This is because the value of cot(pi/N) for an even number of sides will always be irrational, making it impossible to construct the polygon using these tools.
How does the value of N affect the constructibility of regular polygons?
The value of N, or the number of sides in a regular polygon, directly affects the constructibility of the polygon. A regular polygon with an odd number of sides (N) is constructible if and only if cot(pi/N) is a rational number. A regular polygon with an even number of sides is not constructible using a compass and straightedge.
  • Linear and Abstract Algebra
