Relationship between E-field and Probability Amplitude of Waves
In summary, the relationship between the electric field and the probability amplitude is that the intensity is proportional to the square of the E-field amplitude, and also proportional to the square of the probability amplitude. However, there is no direct proportionality between the two as one is a vector and the other is a scalar. The photon state is described by Fock states or its linear combination, while the electric field is associated with a field operator. The bold p in the Schrödinger equation for the photon represents momentum.
tade
721
Electromagnetic waves can be classically described by Maxwell's equations.
Photons can be described by probability waves.In this case, what is the relationship between the electric field and the probability amplitude?
Are they directly proportional to each other? What about the fact that one is a vector and the other a scalar?
The Intensity is proportional to the square of the E-field amplitude, and also proportional to the square of the probability amplitude.
I thought this would be a commonly asked question.
Did you read the thread? Your question stated that photons could be described by probability waves and then asked a question that if that were were the case... The lack of responses would suggest that it cannot be the case.
Yeah I know, but I was asking if you yourself know the answer.
A photon is not a non-relativistic object, this implies that its quantum behavior cannot be described by the (non-relativistic) Schroedinger equation. For non-relativistic particles, you can find its position representation wavefunction by solving the Schroedinger equation. Since you can't do that with photon, there is no spatial wavefunction in the usual sense of non-relativistic QM which can be associated to photons.
Photon state is described by the so-called Fock states or its linear combination. Whereas the electric field, since it's a physical quantity, is associated with a field operator ##\tilde{E}## and the electric field you observe is the average value of this operator with respect to the particular state of the photon, i.e. ##\langle \psi | \tilde{E} | \psi\rangle##. The state ##|\psi\rangle ## can take a number of forms, each of which is a particular linear combination of Fock states, for example number state, coherent state, squeezed state, etc, and again they do not have position representation.
FAQ: Relationship between E-field and Probability Amplitude of Waves
What is the relationship between the electric field and the probability amplitude of waves?
The probability amplitude of a wave is directly proportional to the square root of the electric field strength.
How does the electric field affect the probability of a wave?
The electric field determines the amplitude of a wave, which in turn affects the probability of finding a particle within that wave.
What is the significance of the electric field in wave-particle duality?
The electric field plays a crucial role in describing the behavior of particles as both waves and particles. It helps determine the probability of finding a particle at a specific location.
Does the electric field have an impact on the wavelength of a wave?
Yes, the electric field influences the wavelength of a wave, as it is directly related to the wave's frequency.
What is the mathematical formula for the relationship between the electric field and probability amplitude of waves?
The mathematical formula is Ψ ∝ √E, where Ψ is the probability amplitude and E is the electric field strength.
