Relationship between Fourier coefficients and power spectral density
The discussion focuses on the relationship between Fourier coefficients and power spectral density (PSD), emphasizing Parseval's Theorem. It establishes that the power spectral density, represented as Φ(f_{x_n}, f_{y_m}), is linked to the squared magnitude of Fourier coefficients |c_{n,m}|^2 through integrals and sums. The conversation highlights the distinction between continuous and discrete cases, noting that in the discrete case, the integral can be approximated as a sum over frequency bins. The concept of ergodicity is introduced, suggesting that the ensemble average of |c_{n,m}|^2 can be equated to the time average of the squared magnitude of the Fourier transform. Ultimately, the discussion aims to clarify how these mathematical relationships can be simplified and understood in the context of signal processing.
Skaiserollz89
Show that ##\langle|c_{n,m}|^2\rangle=\Phi(f_{x_n},f_{y_m})\Delta f_{x_n} \Delta f_{y_m}##, where
##\langle|c_{n,m}|^2\rangle## is the ensemble average of fourier coefficients of a phase screen given by ##\phi(x,y)=\sum\sum c_{n,m}e^{i2\pi(f_{x_n}x+f_{y_m})} ##, and ##\Phi(f_{x_n},f_{y_m})## is the phase power spectral density is the squared-magnitude of the fourier transform of ##\phi(x,y)##.
$$\langle|c_{n,m}|^2\rangle=\Phi(f_{x_n},f_{y_m})\Delta f_{x_n} \Delta f_{y_m}$$
$$\phi(x,y)=\sum\sum c_{n,m}e^{i2\pi(f_{x_n}x+f_{y_m}y)} $$
Parseval's Theorem:
$$\int\int_{-\infty}^{+\infty}|\phi(x,y)|^2 \,dx\,dy=\int\int_{-\infty}^{+\infty}\Phi(f_{x_n},f_{y_m}) \,df_x\,df_y.$$
Here, ##\Phi(f_{x_n},f_{y_m})=|\mathscr{F(\phi(x,y))}|^2 ## is the Power Spectral Density of ##\phi(x,y)## and ##\mathscr{F}## is the Fourier transform operator.
Parseval's Theorem relates the phase ##\phi(x,y)## to the power spectral density ##\Phi(f_{x_n},f_{y_m})## by
$$\int\int_{-\infty}^{+\infty}|\phi(x,y)|^2 \,dx\,dy=\int\int_{-\infty}^{+\infty}\Phi(f_{x_n},f_{y_m}) \,df_x\,df_y$$
Substitution of ##\phi(x,y)=\sum\sum c_{n,m}e^{i2\pi(f_{x_n}x+f_{y_m}y)} ## into the left side of Parsevals Theorem yields
$$|c_{n,m}|^2=\int\int_{-\infty}^{+\infty}\Phi(f_{x_n},f_{y_m}) \,df_x\,df_y$$.In ##\langle|c_{n,m}|^2\rangle=\Phi(f_{x_n},f_{y_m})\Delta f_{x_n} \Delta f_{y_m}##, ##\langle|c_{n,m}|^2\rangle## represents the ensemble average of ##|c_{n,m}|^2## and ##\Delta f_{x_n}## and ## \Delta f_{y_m}## represent the frequency bin widths, so we need to consider the discrete nature of the Fourier transform I think.
In the continuous case, the expression ##|c_{n,m}|^2## represents the contribution of the continuous frequency range within the integral to the squared magnitude of the Fourier coefficient ##c_{n,m}##. However, in the discrete case, we can approximate this integral as a sum over the frequency bins.
Thus, we can rewrite the equation as:
$$ |c_{n,m}|^2 \approx \sum_{f_{x_n}} \sum_{f_{y_m}} \Phi(f_{x_n}, f_{y_m}) \Delta f_x \Delta f_y$$where ##\Delta f_{x_n}## and ##\Delta f_{y_m}## represent the width of the frequency bins.
By approximating ##\Phi(f_{x_n}, f_{y_m})## as constant within each sum, it can be moved out in front of the double sum. However, it's important to note that this is an approximation and assumes that ##\Phi(f_{x_n}, f_{y_m})## doesn't vary significantly within each sum.
$$ |c_{n,m}|^2 \approx \Phi(f_{x_n}, f_{y_m})\sum_{f_{x_n}} \sum_{f_{y_m}}\Delta f_x \Delta f_y$$From here, I am not really sure what additional simplifications I can make to get to the result that
$$ \langle|c_{n,m}|^2\rangle=\Phi(f_{x_n},f_{y_m})\Delta f_{x_n} \Delta f_{y_m} $$
but it seems as though the ensemble average has something to do with collapsing the summation.
Any additional help here, or suggestions would be much appreciated.
One way to approach this problem is by considering the concept of ergodicity. In signal processing, ergodicity refers to the idea that the statistical properties of a signal can be determined by a single realization of the signal, as long as the signal is stationary (its statistical properties do not change over time).
In this case, we can consider our signal to be the function ##\phi(x,y)## and its Fourier transform ##\mathscr{F}[\phi(x,y)]##. By assuming ergodicity, we can say that the ensemble average of ##|c_{n,m}|^2## is equivalent to the time average of the squared magnitude of the Fourier transform at a specific point in space.
Using this idea, we can rewrite the ensemble average as:
$$\langle|c_{n,m}|^2\rangle = \frac{1}{T} \int_0^T |\mathscr{F}[\phi(x,y)]|^2 dt$$
where T represents the total time duration of the signal.
We can then apply Parseval's Theorem to this time average, which gives us:
$$\frac{1}{T} \int_0^T |\mathscr{F}[\phi(x,y)]|^2 dt = \frac{1}{T} \int_0^T \int\int_{-\infty}^{+\infty} \Phi(f_{x_n},f_{y_m}) df_x df_y dt$$
Since ##\Phi(f_{x_n},f_{y_m})## is constant with respect to time, we can move it out of the time integral, giving us:
$$\frac{1}{T} \int_0^T \int\int_{-\infty}^{+\infty} \Phi(f_{x_n},f_{y_m}) df_x df_y dt = \int\int_{-\infty}^{+\infty} \Phi(f_{x_n},f_{y_m}) df_x df_y$$
Now, we can equate this result with the previous expression for the ensemble average, giving us:
$$\int\int_{-\infty}^{+\infty} \Phi(f_{x_n},f_{y_m}) df_x df_y = \langle|c_{n,m}|^2\rangle$$
Comparing this with the previous equation we derived, we can see
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
