Relationship between Gravity and Density
In summary, the problem asks for the mass, radius, and volume of object A if it has 10 times the surface gravity of object B (Earth) and the two objects have the same density. By giving names to the quantities and using equations for volume and surface gravity, the ratio between the two objects' radius can be solved for, which can then be used to calculate the mass and volume of object A in terms of object B's mass and radius. The resulting solution is simpler than expected and can be calculated by a neophyte with some understanding of algebra and interest in astrophysics.
uberhikari
It would be greatly appreciated if someone could help me solve this problem.
There are two objects, let's call them object A and object B. Assume that object B is the Earth and object A is some other planet. If object A has 10 times the gravity of object B (Earth) and assuming object A and object B (Earth) have the same density, how do I find the mass, radius, and volume of object A?
Thank you.
Astronomy news on Phys.org
Thank you.
Just some hints:
If the two objects have the same density, then their masses are in proportion to their relative volumes, which is proportional to a power (work it out) of the ratio between their radius values.
If you write out the gravitational field at the surface of each object, that also involves the mass and some other power of that ratio for the radius part.
If you give the ratio of the radius values a name, say k, you can write down the formula for the gravitational field of one object in terms of the mass and radius of the other. If you know what the relative strength of the gravitational field is, then you can solve for the ratio and hence work out the relative radius and mass.
The result is a lot simpler than most people would suspect.
What, exactly, do you mean by "gravity" when you say "10 times the gravity of the earth"? Gravity is a force, depending on distance, not a fixed number. If you mean "the force of gravity at the planet's surface", then the force is proportional to the mass of the planet, which is proportional to it volume, which is proportional to the radius, cubed, but inversely proportional to the square of the radius.
Thank you for your response. And, yes, by gravity I mean "the force of gravity at the planet's surface." I also understand just about everything you said. I understand that the force of gravity is proportional to mass, which is proportional to volume, which is proportional to radius cubed, etc. However, what are those proportions? I know the formula for calculating surface gravity and I know the formula for the volume of a sphere, so how do I figure out those proportions and solve the problem?
Please understand that I'm a neophyte who has some interest in astrophysics but the last time I took a math class was algebra in college 7 years ago. I'm not looking for you to solve the problem, only point me in the right direction.
Just give names to the quantities that you are working with and then work through the equations.
For example, let ##r_A## be the radius of object A, ##r_B## be the radius of object B, and let ##k## be the ratio between them, so ##r_A = k r_B##. You can then let ##m_A## be the mass of object A and ##m_B## be the mass of object B and use the volume ratio to work out what ##m_A## is in terms of ##k## and ##m_B##, and so on.
Thanks for your response. However, I am not sure I understand you. Are you telling me that once I have this equation: rA=krB that I need to solve for k in order to get the ratio between rA and rB? Also, what do you mean by "use the volume ratio to work out what mA is in terms of k and mB"? What is the "volume ratio" and how do I use it as you have advised?
You're on the right track. I was hoping to leave you something to work out for yourself!
For a fixed density, the mass is proportional to the volume.
The formula for volume involves ##r^3##, so if everything else is the same and the radius is increased by factor ##k##, ##r^3## becomes ##(kr)^3## which is the same as ##k^3 r^3## so the mass is increased by a factor ##k^3##.
The formula for the gravitational acceleration in terms of the mass and radius is ##g = Gm/r^2## so the gravitational acceleration ##g_A## for object A is given by the following:
$$g_A = {G m_A}/{r_A}^2 = {G (k^3) m_B } / (k \, r_B)^2 = {G (k^3) m_B } / (k^2 \, r_B^2) = k \, {G m_B}/{r_B}^2 = k \, g_B$$
That means that for constant density, the gravitational acceleration at the surface is proportional to the radius.
I hope can you finish that off from there now!
Note that if the density of the objects is different, the mass is affected in the same proportion.
For example, the Moon has about 27% of the radius of the Earth and about 60% of the density, so the strength of the gravitational field on the surface of the Moon is about 27% of 60% of that of the Earth, which is about 16%.
FAQ: Relationship between Gravity and Density
What is the relationship between gravity and density?
The relationship between gravity and density is that the gravitational force between two objects is directly proportional to their masses and inversely proportional to the square of the distance between them. This means that the denser an object is, the stronger its gravitational force will be.
How does gravity affect density?
Gravity affects density by pulling objects with mass towards each other, causing them to become more compact. This results in an increase in density, as the same amount of mass is now contained in a smaller volume.
Can gravity change the density of an object?
Yes, gravity can change the density of an object. As mentioned before, the gravitational force can cause objects to become more compact, resulting in an increase in density. However, this change is usually very small and only noticeable in objects with extremely strong gravitational forces, such as black holes.
How does density affect the strength of gravity?
The denser an object is, the stronger its gravitational force will be. This is because the more mass an object has, the stronger its gravitational pull will be on other objects. Therefore, objects with higher densities will have stronger gravitational forces compared to objects with lower densities.
Is there a direct correlation between gravity and density?
Yes, there is a direct correlation between gravity and density. As the density of an object increases, so does its gravitational force. This relationship is described by Newton's Law of Universal Gravitation, which states that the strength of the gravitational force is directly proportional to the product of the masses of the objects and inversely proportional to the square of the distance between them.
