Relationship between higgs field and EM field
In summary: If you are looking for a more beginner-friendly introduction to particle physics, I would recommend Joseph Weber's "A Beginner's Guide to Particle Physics" or Matt Strassler's "The Particle at the End of the Universe."
Hellabyte
53
So I'm trying to understand how the Higgs field and Higgs boson are different from the EM field and the photon. Firstly how I understand the photon is that It is the quanta of energy that an electromagnetic field oscillating at a certain frequency can give to some other system. The photon is the smallest possible ripple(of a certain frequency) in the EM field.
I'm inclined to think that the same relationship holds for the Higgs field and the Higgs boson. The way I understand it is that It requires the amount of energy that they are using at the LHC to create the 'ripple' in the Higgs field. The Higgs field exists at a constant 'value' everywhere.
I'm just learning about this stuff myself so I apologize for my lack of knowledge about things that are probably vital to the understanding of the subject. I'm a first year grad student I haven't had any formal training in particle physics though. I would love to hear corrections to my thinking.
Bill_K said:
Sounds good to me!
Well so can you think of the higgs field like an em field except that it has a constant value everywhere whereas the em field can be zero? Obviously its different in the way it interacts with things. However if it is like an em field with a constant value then it has to have a preferred direction right? That seems to imply that it can't be a spatial vector and if it has a constant value everywhere that just leaves the analogue of a scalar field which I'm sure is too simple...
It is quite simple indeed, but you get it right again. That is, after symmetry breaking, there is only one scalar Higgs field remaining, and in the vacuum it is a non-zero constant, at the classical level (the Higgs particle is the deviation from this constant, in the potential direction). But hey, fermions have a constant mass, so they'd better couple to a constant field !
The story is a little less trivial for giving mass to the weak vector bosons.
Wow alright that makes sense, thank you. So the only way that this field can deviate from its constant value is with a higgs boson, which we are looking for.
So fermions interact with the field more simply than the vector bosons which I assume means the W and Z bosons. I've heard the analogy that mass is the drag these particles feel as they move through the higgs field. Can anyone elaborate on any substance to that analogy? It seems bogus because you would have to have a velocity to have mass. Or maybe they are talking about an "acceleration" drag.
The analogy was made popular by a cartoon for a context in the UK long ago I believe. But I also think there is some value in the picture, even though it does not provide any hint as to the "mexican potential" or the breaking itself in general.
One may think at first as all particles being massless. Fermions comes in two independent copies except for opposite helicities, which we count as two different fundamental particles. They propagate freely without mixing at the speed of light. Once the Higgs field is introduced and a gauge is picked, it acquires spontaneously a vacuum expectation non-zero value. This generates a coupling term between the two helicity species, which is the mass term we were missing. In the old days we called this picture "zitterbewegung" if you want to look it up. The "zig-zag" motion at the speed of light generate an effective velocity lower for larger coupling between the two helicities (because the zig-zag transition occurs more rapidly).
Hmm interesting. Any recommendation for a introductory book to learn what you're talking about in more detail? I'm a first year grad student.
Thanks a lot for your responses.
I'll second this request on quality reading material.
Related to Relationship between higgs field and EM field
1. What is the relationship between the Higgs field and the electromagnetic (EM) field?
The Higgs field and the EM field are both fundamental fields in the Standard Model of particle physics. The Higgs field is responsible for giving particles in the universe their mass, while the EM field is responsible for the interactions between charged particles.
2. How does the Higgs field affect the behavior of the EM field?
The Higgs field interacts with the EM field through a process called spontaneous symmetry breaking. This means that as particles move through the Higgs field, they gain mass and interact differently with the EM field. This results in the EM field having different strengths and behaviors depending on the particles interacting with it.
3. Can the Higgs field and the EM field be unified into one single field?
Currently, there is no evidence or theory that suggests that the Higgs field and the EM field can be unified into one single field. They have different properties and behaviors, and unifying them would require a significant change in our understanding of fundamental physics.
4. How does the Higgs field explain the existence of mass in the universe?
According to the Standard Model, particles gain their mass by interacting with the Higgs field. The Higgs field permeates the entire universe, and particles moving through it experience a drag-like effect, which gives them mass. Without the Higgs field, particles would not have mass, and the universe would look very different.
5. Is there a relationship between the Higgs field and the electromagnetic force?
The Higgs field and the electromagnetic force are related in the sense that the Higgs field affects the behavior of the EM field. However, the EM force is one of the four fundamental forces of nature, while the Higgs field is a fundamental field that interacts with all particles in the universe. So, while there is a relationship, they are not the same thing.
