Relationship between pressure and volume
In summary: The ideal gas law states PV = nRT. So if n1 and n2 are the numbers of moles of gas in the sample and the temperature is T, then the pressure would be P = n1RT + n2RT.
Amith2006
427
Sir,
Two different isothermal curves representing the relationship between pressure and volume at a given temperature of the same ideal gas are shown for masses M1 and M2 of the gas respectively in the following figure, then which is greater M1 or M2?
a) Please show your work first.
b) I can't see the attachment, but here's a hint : what does the Ideal Gas Law state? How does this bear on your problem?
Sir,
I solved it the following way:
From the figure T1>T2. But according to ideal gas law, Temperature is inversely proportional to mass of gas. Therefore M1<M2.Is it right?
But the question states that the ideal gas is at a given temperature. Doesn't this mean that T1=T2?
The ideal gas equation says
[tex]PV = nRT[/tex]
The number of moles of the gas is given by (m = mass of gas, M = molar mass)
[tex]n = \frac{m}{M}[/tex]
So
[tex]PV = \frac{m}{M}RT[/tex]
Solving for m, the mass of the gas
[tex]m = \frac{PV}{RT}M[/tex]
If you draw a vertical line (parallel to the P-axis) it cuts the two curves at pressures [itex]P_{2}[/itex] and [itex]P_{1}[/itex]. Clearly [itex]P_{2} > P_{1}[/itex]. Also [itex]T_{2} > T_{1}[/itex] (can you see why?). I think I have said more than enough.
Amit, it is not correct to say that the temperature is inversely or directly proportional to the mass of the gas unless pressure and volume are constant. As you can see here, pressure and temperature are different for the two gases.
Do you know what an isotherm is?
I would agree with Pizzasky's interpretation of the problem. The two graphs are the isotherms for two different quantities of the same gas for the same temperature. Since PV (the area of the rectangle with corners on the origin and on the curve) is greater for M2, this means that n2RT > n1RT so M2>M1.
AM
If you say that the temperatures are equal, then you and Pizzasky are correct. It seems that the wording suggests so. Fine.
Maverick,
I agree with AM and Pizza. If the number of moles of the gas is unknown, you can't say that the outer isotherm corresponds to a higher temperature. An isotherm that is farther from the origin can also be generated at the same temperature by increasing the number of moles in the sample.
In this case, if you allow the number of moles (through the total mass) and the temperature to float, you can't make any meaningful comparison. One of the two must be fixed, and that would be the temperature.
Edit : I wrote this before I saw your last post.
FAQ: Relationship between pressure and volume
What is the relationship between pressure and volume?
The relationship between pressure and volume is known as Boyle's Law, which states that when the temperature of a gas is held constant, the pressure of the gas is inversely proportional to its volume. This means that as pressure increases, volume decreases, and vice versa.
How does pressure affect volume?
As pressure increases, the molecules of a gas are forced closer together, resulting in a decrease in volume. This is because the increased pressure causes the gas molecules to collide more frequently and with more force, decreasing the space between them.
What is the equation for Boyle's Law?
The equation for Boyle's Law is P1V1 = P2V2, where P1 and V1 are the initial pressure and volume, and P2 and V2 are the final pressure and volume. This equation shows the inverse relationship between pressure and volume, as the product of the two remains constant.
How does temperature affect the relationship between pressure and volume?
Boyle's Law only applies when the temperature of a gas is held constant. If the temperature were to increase, the molecules would have more energy and move faster, causing an increase in pressure and volume. This would result in a different relationship between pressure and volume, known as Charles's Law.
What are some real-life applications of the relationship between pressure and volume?
The relationship between pressure and volume is important in many scientific and everyday situations. For example, it explains how a balloon expands when filled with air, how a syringe works, and how scuba divers must monitor their air tanks to avoid issues with pressure changes at different depths. It is also used in the design of engines and other machines that involve the compression and expansion of gases.
