Relationship between primitive roots of a prime
In summary, the conversation discusses the relationship between an odd prime number p, primitive roots g and h modulo p, and the integers a, s, and t. The main question is to show that s is congruent to t modulo 2. Hints are given and a potential solution using the fact that g is a power of h is proposed. The conversation then moves on to determining the possible equations for s and t, as well as the number of square residues for each primitive root.
thomas430
Hi all,
I've been staring at this question on and off for about a month:
Suppose that p is an odd prime, and g and h are primitive roots modulo p. If a is an integer, then there are positive integers s and t such that [tex]a \equiv g^s \equiv h^t[/tex] mod p. Show that [tex]s \equiv t[/tex] mod 2.
I feel as though understanding this will give me greater insight into primitive roots, but I'm having trouble even getting started.
Hints, or a push in the right direction would be great!
h is a power of g.
If k is the index of h, then
[tex]h \equiv g^k \: mod \: p [/tex]
and:
[tex]g^s \equiv (\left g^k )\right ^t \: mod \: p[/tex]
Is that the right idea?
So...
[tex]g = h^k, \:for\: (k,p-1)=1[/tex]
substituting:
[tex]g^s \equiv \left( g^k \right)^t \: mod \: p[/tex]
or
[tex]g^s \equiv \left( g^t \right)^k \: mod \: p[/tex]
We know that if p|ab, then p|a or p|b.. so:
[tex]g^s \equiv g^t \: mod \: p[/tex]
Is that correct? What would come next?
thomas430 said:
So...
substituting:
or
decide what are the 2 possibilities for the equation s = kt mod 2 More to the point how many square residues are there for each primative root and which ones are they?
FAQ: Relationship between primitive roots of a prime
What is a primitive root of a prime?
A primitive root of a prime number p is an integer r that has the property that every integer coprime to p is congruent to a power of r modulo p. In other words, r is a generator of the multiplicative group of integers modulo p.
How many primitive roots does a prime have?
A prime number p has φ(p-1) primitive roots, where φ is Euler's totient function. For example, the prime number 7 has φ(6) = 2 primitive roots, which are 3 and 5.
What is the relationship between primitive roots and the order of a prime?
The order of a prime number p is the smallest positive integer k such that p divides k^p-1 - 1. The primitive roots of p are precisely the numbers with order p-1.
Can a composite number have primitive roots?
No, a composite number cannot have primitive roots. This is because a primitive root must have the property that every integer coprime to p is congruent to a power of that root modulo p. However, for a composite number, there will always be integers that are not coprime to it, making it impossible for a primitive root to satisfy this property.
How are primitive roots used in cryptography?
Primitive roots have important applications in cryptography, specifically in the Diffie-Hellman key exchange algorithm. In this algorithm, two parties can agree on a secret key without directly exchanging it, using the properties of primitive roots and modular arithmetic.
