Relationship between the age of the Universe and the Hubble horizon
In summary: This is simply because when looking at any distance, the expansion of space has already traveled that distance and thus is already at c.
Anthony111
i got a bit lost in the responses to my last question so I am guessing this one is really going to be beyond me.
Assumptions I have used for my questions are:
· Speed of light = 299792.458 km/s
· Hubble constant = 71 km/s/Mpc (I know about the tension of H0 being 68 and 73 but don't think it alters my question)
· 1 Mpc = 30,856,776,000,000,000,000 km
· 1 Mpc = 3,261,563.7967311 ly
· 1ly = 365.25 days1. At a Hubble constant of 71km/s/Mpc it would take space 13,771,721,514.72 years to contract from a from 1 Mpc in distance.
30,856,776,000,000,000,000 km / 71 km/s = 434,602,478,873,239,436.619718 seconds
434,602,478,873,239,436.619718 seconds / 60 = 7.243,374,647,887,323.943661 minutes
7.243,374,647,887,323.943661 minutes / 60 = 120,722,910,122.085727 hours
120,722,910,122.085727 hours /24 = 5,030,121,283,255.086071 days
5,030,121,283,255.086071 days / 365.25 = 13,771,721,514.72 years
As I understand it, this is how we approximate the age of the universe. (I say approximate as H0 has decayed over time)2. At a Hubble constant of 71km/s/Mpc the rate of the expansion of space would take 13,771,721,514.72 ly to be traveling at c away from a given point.
299792.458 km/s / 71 km/s = 4222.428985 Mpc
4222.428985 Mpc * 3,261,563.796731 ly = 13,771,721,514.72 ly
This is simply telling us how far from a single point it would take the expansion of space to be expanding at c. It seems to be a different calculation and yet the answer is the same other than the first one is years in time and the second one is light years in distance.
Why is it that the age of the universe seems to be equal to the expansion of space reaching light speed?
Space news on Phys.org
When you look at the Hubble constant, you should notice that its dimensions are [distance]/[time]/[distance]. So it's actually equivalent to 1/[time].
This simply means that H tells you that if you pick any distance whatsoever, it will have grown to its current value in some characteristic time. By working out the units you end up with something like 1/144% per million years, or indeed 100% per ~13.8 billion years (under the assumption H stays constant in time). That's the time needed for any distance to grow from 0 to its current value.
It follows that a point that is farther away needs higher recessional velocity to cover its higher distance in the same time (that's just Hubble's law).
So if you now look at how H0 is expressed in the traditional units, i.e. ~70 km/s/Mpc, it tells you that a point that is 1 Mpc away needs this particular velocity of ~70 km/s to cover the distance of 1 Mpc in 13.8 Gyr. 2 Mpc would require 140 km/s, and so on.
Now, it should be unsurprising that if instead of 1 or 2 Mpc we pick a distance that is equal to 13.8 Gyr times the speed of light (13.8 Glyr), the speed required to cover this distance in 13.8 Gyr is going to be c.
Related to Relationship between the age of the Universe and the Hubble horizon
1. What is the Hubble horizon and how does it relate to the age of the Universe?
The Hubble horizon is the maximum distance that light can travel since the beginning of the Universe, also known as the observable universe. The age of the Universe is directly related to the Hubble horizon because the light we receive from distant objects has taken a certain amount of time to reach us, which gives us an idea of how long the Universe has been expanding.
2. How is the Hubble horizon calculated?
The Hubble horizon is calculated using the Hubble constant, which is a measure of the rate of expansion of the Universe. This constant is then used to determine the distance that light has traveled since the beginning of the Universe.
3. Can the Hubble horizon change over time?
Yes, the Hubble horizon can change over time as the Universe continues to expand. This means that the observable universe is constantly getting larger and objects that were previously beyond the Hubble horizon may eventually come within our observable range.
4. What is the significance of the relationship between the age of the Universe and the Hubble horizon?
The relationship between the age of the Universe and the Hubble horizon is significant because it gives us an understanding of the history and expansion of the Universe. By studying the Hubble horizon, we can learn about the early stages of the Universe and how it has evolved over time.
5. How does the Hubble horizon affect our understanding of the Universe?
The Hubble horizon is crucial in our understanding of the Universe as it allows us to observe objects that are billions of light-years away. This helps us to study the formation and evolution of galaxies, as well as the structure and composition of the Universe as a whole.
  • Cosmology
  • Cosmology
